OrangepiPC (OS Armbian) - Successful upgrade from version 3.1 to version 3.5
FIRST ATTEMPT: FAILED
pi@orangepipc:~$ sudo apt-get update
pi@orangepipc:~$ sudo apt-get install piaware
[sudo] password for pi:
Reading package lists... Done
Building dependency tree
piaware is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@orangepipc:~$ sudo apt-get install dump1090-fa
dump1090-fa is already the newest version.
If you click an airplane icon, an info screen pops up. You used to be able to click the top, left corner (registration number, I think) to center the plane on the display. The page would then track the centered plane. That feature seems to be gone now, unless there is another way to trigger it.
You can doubleclick on the table entry or the aircraft icon itself but we do seem to have lost the ability to do it from the info window, Iâll see about getting that fixed.
Coming from 3.1.0, you used to be able to set âChartBundleLayers = trueâ in the config.js file to get a couple other layers. This setting appears to no longer work. I only have the 5 options under âoverlay togglesâ
Has this been removed or relocated to a different spot?
Curious about what happened to âday of upgradeâ data ⌠My Tuesday (4/4) data just âwent awayâ after having been posted before.
3.5.0 seems to perform better than the previous version I installed a couple weeks ago.
So, if I shut down my PiAware unit, format the SD card, and install a new image, and turn it back on, does this mean all my statistical data, site number, and âbroadcasting sinceâ data will all be wiped out?
Your current site is identified by hardware MAC address so if you are still running on the same hardware, you donât need to do anything special to continue using your existing site.
Anyone using piaware 3.5 checked ChartBundle maps today?
I just reloaded a fresh load of 3.5 and made the customizations I normally do for my network etc. I then edited config.js file for Bing maps. extra range rings, and ChartBundle. Everything works fine except I am getting blank base layer when I select any aviation map.
Do I need to dig more, does it not work with 3.5, or is the map server down???
Hello,
since this morning, i have not column âdistanceâ on Skyview list and i have âunknown versionâ also in skyview, but on my page it is indicated Feeder Type: PiAware (SD Card) 3.5.0
Have everybody this problem, what can i do to see Distance?
i reboot pi but same problem
Station LFMC
Small bug in the stylesheet for v3.5.0, the font-family is defined as Helvetica Neue only with no backup through a large portion of the doc, the initial entry is OK.
I noticed that the table used a Serif font and work (Windows) and a Sans Serif (Mac) font at home so I went digging.
The stylesheet initially defines the font-family as Helvetica Neue, Sans-Serif; but then only as Helvetica Neue later on. My Mac at home has this font family installed, my PC at work doesnât.
If you add Sans-Serif to all the families using Helvetica it all looks fine.
