Running a flightaware pro plus stick with black flightaware antenna. Cean pi install with piaware main software and fr24 feeder. Been getting really good hits with this setup. Thought I’d add a AirNav RadarBox 1090 MHz ADS-B Filter behind it since I’m in the NY/NJ metro area. Now with the filter I’m getting a weird phenomena. On piaware the total aircraft and positions dropped by almost 15%. Yet on fr24 I gained nearly 20%. Its pretty significant. You can see the results immediately after installing the filter. I remove it and everything evens out again.
Also noticed over all everything has dropped. Maybe due to the bad weather in the area.
I might just yank off the filter and leave it be. Maybe I’ll try the uptronics preamp with filter.
The past two days after introducing the filter into the setup, It seems its a drop between BOTH platforms. Its just FR24 is showing a slight “advantage” over FA.
What is your gain setting for dump1090?
Which one you have, dump1090-fa or dump1090-mutability?
Which image are you using (Raspbian image, or Pi24 image, or Piaware SD card image)?
Running a rasbian image. Dump 1090fa. Gain is still at default -10. Before the filter, I did play around with the settings and +40 gave the second best results to the default setting.
My experience exactly. We must have received defective units. The RadarBox stick cost the same as the FA Pro Plus on Amazon Canada, so the choice is an easy one for me.
Regarding the RadarBox filter, I was thinking of getting one, no more.
My experience so far is:
for quick and cheap - FA Pro Plus;
a little more money and trouble - RTL-SDR Blog v3 and RTL-SDR Blog LNA+filter combo.
To make option 2 easier, I’m considering the NooElec SmarTee, instead of the RTL-SDR Blog stick, because of the always ON bias-tee.
My case is exactly opposite.
I see almost negligible aircraft when I remove filter and connect antenna directly to the ProStick Plus:
NOTE:
Every time I removed and inserted the Filter, I made sure that all connectors are fully tightened, so the drastic drop is not due to loose connection. Actually I have several Cell/Mobile phone companies antennas on my building as well as adjuscent buildings, which causes overload of the LNA of ProStick Plus, and its SAW chip being located after the LNA, cannot protect the LNA from overload.
I hope in next version of Pro Stick Plus which is due to be released shortly, they will either relocate the SAW filter between LNA and input SMA connector, or may be add one more SAW between SMA connector and LNA. Let us wait and see.
Up to 21:20 EDT > Antenna connected to Pro Stick PLUS through FA Light Blue Filter
From 21:20 to 21:50 EDT > Antenna connected to Pro Stick PLUS directly (Filter removed).
From 21:50 to 22:00 EDT > Antenna connected to Pro Stick PLUS through FA Light Blue Filter
From 22:00 to 22:25 EDT > Antenna connected to Pro Stick PLUS directly (Filter removed).
From 22:25 EDT to end of graph > Antenna connected to Pro Stick PLUS through FA Light Blue Filter
