Morning
I see a l ot of posts explaining how to do things in the command line using sudo apt-get… type commands. The PI output page of the pi being access page shows a"Alt+F2" to access the command line.
Plugging a usb keyboard into the pi does not respond to the keystrokes, so I assume there is more to it.
Trying to do things like install packages to the Pi (32gb sd card so I assume I have room…)
Since the keyboard doesn’t seem to connect, pressing Alt+F2 does nothing, tried putty - connection refused.
Intent is to set up a GPS dongle to whatever Pi I am using (zero 2w is just an educational test bed likely a 4b 2gb for the intended device
The pi-aware config.txt file has “use-gpsd yes”, Is there more that i need to do?
The wireless keyboard may be a good call. Didn’t think about the power draw required. I have one handy, and will give it a go.
Mostly because ai want a “Mobile” unit to take with me on trips without having to reset the lat/long manually. I wouldn’t be using it like a regular gps device to constantly fix my position. If I need to do it manually at my destination that fine, I can do that. For instance sitting on a highrise balcony in Chicago overlooking Lake Michigan, or sitting in my jeep on a beach like in Key West.
Way too much time on my hands, or hand rather. I’m on a medical leave so I’m trying to keep my mind busy. (nothing serious, rotator cuff repair.)
SSH is enabled, and I have windows available, so a cmd approach may work.
