Add FlightAware feed to FR24 build
I have a running setup for FR24. Wondering if anyone has an easy to follow guide on how to setup my Pi to also feed to FlightAware?
Also, not quite sure how to gain access to command line, if someone could explain that process as well.
Thanks!
To gain access to the pi from another computer many of us use a program named Putty. PuTTY: a free SSH and Telnet client The web page contains a download link for the putty installer. Just updated my install and working well. You will need the username and password of the pi to log in. Good idea to set your Pi network address as the default address for Putty to simplify connections in the future.
To add Piaware to your current system, go to PiAware - bauen Sie Ihre eigene ADS-B Bodenstation zur Integration mit FlightAware - FlightAware and follow the instructions there. That address shows some German language (on my windows 7 system) for some reason but it works in English.
Thank you! I spent the AM getting everything all setup and working!
I formatted my SD card and then followed the FlightAware instructions adding PiAware. I then added each of my other services (FR24, PlanerFinder, ADBSExchange, and RadarBox) and everything is up and running great…
Woo!
Welcome to the forum @AustonnL - you will get a lot of helpful advice here as your enthusiasm grows.
I think the Flightaware installation seems to be the easiest then add feeders to that.
Geffers
