3G USB Modem Script
If I enter the following at the command line my usb 3g modem will connect to the internet.
sakis3g --sudo connect --sudo USBINTERFACE=“3” --sudo APN=“telstra.internet”
I tried the below script called: /etc/init.d/modem-on - with the following content:
#!/bin/sh
sleep 1.2m ;
exec /home/opi/usr/local/bin/sakis3g --sudo connect --sudo USBINTERFACE=“3” --sudo APN=“telstra.internet”
exit 0
It did not work on startup. What am I doing wrong? I want to insert the usb, turn the power on and walk away from a remote feeder.
V1.) So I have sakis3g installed
2.) So I created a file : sudo nano /etc/sakis3g.conf with the following info:
USBINTERFACE=“3”
MODEM=“19d2:0031”
3.) I created an autconnectnet script - sudo nano /etc/init.d/autoconnectnet with the following:
#! /bin/sh
BEGIN INIT INFO
Provides: noip
Required-Start: $remote_fs $syslog
Required-Stop: $remote_fs $syslog
Default-Start: 2 3 4 5
Default-Stop: 0 1 6
Short-Description: Simple script to start a program at boot
Description: A simple script from www.stuffaboutcode.com which will start / stop a program a boot / shutdown.
END INIT INFO
case “$1” in
start)
sleep 10
echo “connecting via sakis3g”
# run application you want to start
/usr/local/bin/sakis3g --sudo “connect”
stop)
echo “dissconnecting via sakis3g”
# kill application you want to stop
/usr/local/bin/sakis3g --sudo “disconnect”
echo “Usage: /etc/init.d/autoconnectnet {start|stop}”
exit 1
esac
exit 0
If I type: sudo /etc/init.d/autoconnectnet start or sudo /etc/init.d/autoconnectnet stop it starts and stops no problems.
I also added sudo update-rc.d autoconnectnet defaults
4.) Now, when I switch the power off and back on, this .conf file seems to get corrupted or modified. The following is displayed when try to go back to this entry - sudo nano /etc/sakis3g.conf and the editor is blank.
Error reading lock file /etc/.sakis3g.conf.swp: Not enough data read
What am I doing wrong? I want the modem to start after powering on.
My computer ended up with issues so I have restarted afresh.
