Why do I not have any MLAT Data?
So with the new update I am not receiving any MLAT data…
Why?
We’ll need a little more to go on to help you out. What kind of hardware are you running? Which software did you update? Does /tmp/piaware.out give any clues? If you are running dump1090-mutability, can you check /var/log/dump1090-mutability?
Your site location is not set. Set it here: flightaware.com/adsb/stats/user/moone
Running a Piware system, no updates and I’ve never had the time to learn the dump1090 stuff so basically a stock system with a spider antenna…
Lately the #'s have been down from ealier in the summer and I don’t know if that’s seasonal or equipment related as I’ve not changed anything since I plugg’d in the Pi. ???
Ok, did that with the elevation as well…
Is there something else I need to do or does this do everything on it’s own?
You may need to restart piaware to make it notice the updated location, otherwise nothing special should be needed.
It didn’t like me using the web interface to reboot it so I had to go and unplug it yesterday to get it to restart but it appears to be working.
Thanks!!!
