i have just set up a raspberry pi 3 and think its great
what i am wondering is could i use a pi 1 or 2 and set one of them up, what model of pi can be used, i ask because i am thinking about getting a couple of old pi’s setting them up and giving them to friends.
Goofing around with spare parts yesterday, I cobbled together a a test Pi 1 (B+) system using the FA SD card image and I wouldn’t recommend it on that hardware. Go with at least a Pi 2 or 3. The Pi 1 works when overclocked to Turbo but runs 100% CPU at medium setting, and that’s with fewer than 60 planes being tracked.
I run a Pi2 here feeding both FA and FR24. My position in Sydney can see me tracking up to 50 planes at up to 250nm range. The Pi2 does it without breaking a sweat, so I can’t see any reason to upgrade it to a Pi3.
ditto here,
pi2 with 130 planes tracked & on station at the time I write this post.
cpu 9%, memory 20%,32gb card installed and this is 8% used (never gone above 9% in 1 year running)
Station feeding fa,pf and fr24 using joes script.
My backup station,Pi b+ runs fine also with 8gb card, no issues.
Run everything required including station logging using painless scripted install,
I’m running my FA stuff on a Pi2 without a hitch, it runs great, and it never has shut down or hung since I put it in place over 3 months ago.
I have been able to do several upgrades (apt-get update and apt-get upgrade) while it was running and it came back to life in a couple of minutes. It didn’t even affect my streak for how many days I have been up.
I am running the 3.1.0 image with a few of my own tweaks, but they’re miner.
It depends on your plane traffic and your antenna. I have a Pi2 which is running at 90% CPU the whole time. It is picking up 150+ planes a day and 1200 mesaages per second. As you are in Birmingham, UK, you have the potential to collect a lot of traffic. Once you get hooked on ADSB, you’ll want to improve your antenna and setup and it may well overpower a Pi2. The cost of a Pi2 vs Pi3 is minimal so I would go for Pi3. There will be enough power to run other applications alongside ADSB too
