Greetings all!
Having trouble getting the lighttpd webserver working on Beaglbone Black with Ted Sluis dump1090-mutability. Found here GitHub - tedsluis/dump1090: Dump1090 is a simple Mode S decoder for RTLSDR devices
Fresh SD card with Jessie downloaded from BeagleBoard.org - latest-images
OS installed and updated.
RTL-SDR installed and confirmed working.
Lighttpd installed.
Built in services that use port 8080 all stopped.
Lighttpd enabled, force-reload, confirmed running.
Dump1090 started, confirmed running, receive packets confirmed.
./dump1090 --net --write-json /run/dump1090-mutability --write-json-every 1
Page is successfully served at ip_address/dump1090/gmap.html.
Page can be modified with the config.js file. Title, marker, default center, zoom level.
Problem - Flight data never appears.
Fresh SD card with Stretch downloaded from same address as above.
OS installed and updated. Some additional fun with chromium.
Lighttpd installed.
Built in services that use port 8080 all stopped. Some slight command differences required from Jessie.
Problem - Flight data never appears here either.
What am I missing?
