Hi,
I changed from the Flightaware dump1090 to the mutability dump1090 on two of my four raspberry’s and now I no longer being able to feed one dump1090 with TCP Beast output from an other raspberry with the new dump1090-mutability.
I thought I could replace the dump1090 flightaware version of dump1090 for the mutability version? Or am I wrong?
My four raspberry’s run piaware and dump1090. I have four different antenna’s.
This is my setup:
**host ted1090-1 (IP 192.168.11.44 ) **
- piaware 2.1-1 (mlat disabled)
- dump1090 (1.2-2 flightaware version)
- should also listen to the dump1090 on ted1090-2 (IP 192.168.11.34) & ted1090-3 (192.168.11.32) using netcat:
nc -d 192.168.11.34 30005 | nc 127.0.0.1 30004 &
nc -d 192.168.11.32 30005 | nc 127.0.0.1 30004 &
This host no longer connects over port 30005 to ted1090-3 (IP 192.168.11.32 ) since the dump1090 upgrade on host ted1090-3 to mutability.
Netstat show this:
pi@ted1090-1 ~ $ sudo netstat --program --protocol=inet --tcp --wide --all
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 *:http-alt *:* LISTEN 1962/dump1090
tcp 0 0 *:30001 *:* LISTEN 1962/dump1090
tcp 0 0 *:30002 *:* LISTEN 1962/dump1090
tcp 0 0 *:30003 *:* LISTEN 1962/dump1090
tcp 0 0 *:30004 *:* LISTEN 1962/dump1090
tcp 0 0 *:30005 *:* LISTEN 1962/dump1090
tcp 0 0 *:ssh *:* LISTEN 2184/sshd
tcp 94 0 localhost:30004 localhost:58627 ESTABLISHED 1962/dump1090
tcp 0 0 192.168.11.44:40360 192.168.11.34:30005 ESTABLISHED 2346/nc
tcp 748 0 localhost:48133 localhost:30005 ESTABLISHED 2226/faup1090
tcp 0 0 192.168.11.44:32822 eyes.flightaware.com:1200 ESTABLISHED 2150/piaware
tcp 0 1131 localhost:30005 localhost:48133 ESTABLISHED 1962/dump1090
tcp 0 117 localhost:58627 localhost:30004 ESTABLISHED 2347/nc
**host ted1090-2 (IP 192.168.11.34) **
- piaware 2.1-1 (mlat enabled)
Netstat looks good. Connections to ted1090-1 (IP 192.168.11.44) and ted1090-4 (IP 192.168.11.8) over port 30005:
pi@ted1090-2 ~ $ sudo netstat --program --protocol=inet --tcp --wide --all
tcp 0 0 *:http-alt *:* LISTEN 1878/dump1090
tcp 0 0 *:30001 *:* LISTEN 1878/dump1090
tcp 0 0 *:30002 *:* LISTEN 1878/dump1090
tcp 0 0 *:30003 *:* LISTEN 1878/dump1090
tcp 0 0 *:30004 *:* LISTEN 1878/dump1090
tcp 0 0 *:30005 *:* LISTEN 1878/dump1090
tcp 0 0 *:ssh *:* LISTEN 2138/sshd
tcp 0 0 192.168.11.34:50793 earrs.hou.flightaware.com:1200 ESTABLISHED 2113/piaware
tcp 0 0 localhost:30005 localhost:37289 ESTABLISHED 1878/dump1090
tcp 0 0 192.168.11.34:30005 192.168.11.44:40360 ESTABLISHED 1878/dump1090
tcp 0 0 localhost:54461 localhost:30004 ESTABLISHED 3009/fa-mlat-client
tcp 0 0 192.168.11.34:30005 ted1090-4.bachstraat20:42710 ESTABLISHED 1878/dump1090
tcp 0 0 localhost:37289 localhost:30005 ESTABLISHED 3009/fa-mlat-client
tcp 134 0 localhost:37284 localhost:30005 ESTABLISHED 2182/faup1090
**host ted1090-3 (IP 192.168.11.32) **
- dump1090 (1.14 mutability version)
- This host no longer connects to ted1090-1 (IP 192.168.11.44) and ted1090-4 (IP 192.168.11.8) over port 30005 since the upgrade to dump1090 mutability!
Netstat:
pi@ted1090-3 ~ $ sudo netstat --program --protocol=inet --tcp --wide --all
tcp 0 0 *:http *:* LISTEN 2166/lighttpd
tcp 0 0 localhost:10001 *:* LISTEN 1830/dump1090-mutab
tcp 0 0 localhost:30001 *:* LISTEN 1830/dump1090-mutab
tcp 0 0 localhost:30002 *:* LISTEN 1830/dump1090-mutab
tcp 0 0 localhost:30003 *:* LISTEN 1830/dump1090-mutab
tcp 0 0 localhost:30004 *:* LISTEN 1830/dump1090-mutab
tcp 0 0 localhost:30005 *:* LISTEN 1830/dump1090-mutab
tcp 0 0 *:ssh *:* LISTEN 2126/sshd
tcp 0 0 ted1090-3:46073 eyes.flightaware.com:1200 ESTABLISHED 1997/piaware
tcp 0 0 localhost:30004 localhost:59109 ESTABLISHED 1830/dump1090-mutab
tcp 0 0 localhost:53668 localhost:30005 ESTABLISHED 2208/fa-mlat-client
tcp 0 1011 localhost:30005 localhost:53667 ESTABLISHED 1830/dump1090-mutab
tcp 0 0 localhost:30005 localhost:53668 ESTABLISHED 1830/dump1090-mutab
tcp 1011 0 localhost:53667 localhost:30005 ESTABLISHED 2206/faup1090
tcp 0 0 localhost:59109 localhost:30004 ESTABLISHED 2208/fa-mlat-client
**host ted1090-4 (IP 192.168.11.8) **
- should also listen to the dump1090 on ted1090-2 & ted1090-3 using netcat:
This host no longer connects over port 30005 to host ted1090-3 (IP 192.168.11.32) since the dump1090 upgrade on host ted1090-3 to mutability.
However, it still connects to ted1090-2 with the dump1090 flightaware version over port 30005!
Netstat shows this:
pi@ted1090-4 ~ $ sudo netstat --program --protocol=inet --tcp --wide --all
tcp 0 0 *:http *:* LISTEN 2504/lighttpd
tcp 0 0 localhost:10001 *:* LISTEN 1853/dump1090-mutab
tcp 0 0 localhost:30001 *:* LISTEN 1853/dump1090-mutab
tcp 0 0 *:8754 *:* LISTEN 2048/fr24feed
tcp 0 0 localhost:30002 *:* LISTEN 1853/dump1090-mutab
tcp 0 0 localhost:30003 *:* LISTEN 1853/dump1090-mutab
tcp 0 0 localhost:30004 *:* LISTEN 1853/dump1090-mutab
tcp 0 0 localhost:30005 *:* LISTEN 1853/dump1090-mutab
tcp 0 0 *:ssh *:* LISTEN 2282/sshd
tcp 0 81 localhost:56352 localhost:30004 ESTABLISHED 2538/nc
tcp 0 0 ted1090-4.bachstraat20:42705 192.168.11.34:30005 ESTABLISHED 2457/nc
tcp 0 0 ted1090-4.bachstraat20:42832 eyes.flightaware.com:1200 ESTABLISHED 2018/piaware
tcp 0 0 localhost:39257 localhost:30002 ESTABLISHED 2048/fr24feed
tcp 49 0 localhost:30004 localhost:56348 ESTABLISHED 1853/dump1090-mutab
tcp 0 1034 localhost:30005 localhost:46223 ESTABLISHED 1853/dump1090-mutab
tcp 0 0 localhost:30002 localhost:39257 ESTABLISHED 1853/dump1090-mutab
tcp 2036 0 localhost:46223 localhost:30005 ESTABLISHED 2337/faup1090
I question is why can hosts ted1090-1 and ted1090-4 no longer connect to ted1090-3 over port 30005 after I upgraded this host tot dump1090-mutability?
The dump1090’s are running on all four hosts. This shows that dump1090-mutability is running on host ted1090-3:
pi@ted1090-3 ~ $ ps -ef | grep dump
dump1090 1830 1 31 08:06 ? 00:35:16 /usr/bin/dump1090-mutability --net --ppm 0 --oversample --fix --phase-enhance --max-range 300 --net-http-port 0 --net-ri-port 30001 --net-ro-port 30002 --net-bi-port 30004 --net-bo-port 30005 --net-sbs-port 30003 --net-fatsv-port 10001 --net-heartbeat 60 --net-ro-size 500 --net-ro-interval 1 --net-buffer 2 --net-bind-address 127.0.0.1 --stats-every 3600 --write-json /rundump1090-mutability --write-json-every 1 --json-location-accuracy 1 --quiet
pi 2488 2214 0 09:59 pts/0 00:00:00 grep --color=auto dump
The option –net-bo-port 30005 (default) should give TCP Beast output on port 30005.
And piaware runs as well on all four raspberry’s. Even on host ted1090-3 it is sending messages to flightaware every 5 minutes!
When I stop dump1090-mutability on host ted1090-3 and I start the dump1090 flightaware version, it works as it should.
Why isn’t it working with the dump1090-mutability? What is wrong? How can I fix this?
