Was my blue receiver just fried?
We just had a very strong storm blow through. I have two receivers. The one that had been out of service for a while was just starting to ramp up again. I was watching the stats steadily improve. Then the storm hit, and activity dropped to zero. Investigating, I determined that the power supply was fried, so I replaced it with another, and the RPi zero starts up just fine. My local connection shows a map but no aircraft and Skyaware unknown version. Is the receiver fried? Or maybe I need to just re-image the SD card? If I do the latter, how can I continue with the same site ID: 24859.
Here’s what I can see of the logs (storm started around 18:30 local):
Refresh Log Refresh Log
[2025-05-28 17:05 CDT] 1694592 msgs recv’d from dump1090-fa (2644 in last 5m); 1694592 msgs sent to FlightAware
[2025-05-28 17:10 CDT] 1697141 msgs recv’d from dump1090-fa (2549 in last 5m); 1697141 msgs sent to FlightAware
[2025-05-28 17:12 CDT] mlat-client(3202): Server: 0.0 kB/s from server 0.0kB/s TCP to server 2.6kB/s UDP to server
[2025-05-28 17:12 CDT] mlat-client(3202): Results: 11.7 positions/minute
[2025-05-28 17:12 CDT] mlat-client(3202): Server status: synchronized with 409 nearby receivers
[2025-05-28 17:12 CDT] mlat-client(3202): Receiver status: connected
[2025-05-28 17:12 CDT] mlat-client(3202): Receiver: 586.0 msg/s received 276.3 msg/s processed (47%)
[2025-05-28 17:12 CDT] mlat-client(3202): Aircraft: 13 of 19 Mode S, 58 of 90 ADS-B used
[2025-05-28 17:15 CDT] 1699746 msgs recv’d from dump1090-fa (2605 in last 5m); 1699746 msgs sent to FlightAware
[2025-05-28 17:20 CDT] 1702304 msgs recv’d from dump1090-fa (2558 in last 5m); 1702304 msgs sent to FlightAware
[2025-05-28 17:25 CDT] 1705008 msgs recv’d from dump1090-fa (2704 in last 5m); 1705008 msgs sent to FlightAware
[2025-05-28 17:27 CDT] mlat-client(3202): Receiver status: connected
[2025-05-28 17:27 CDT] mlat-client(3202): Results: 16.4 positions/minute
[2025-05-28 17:27 CDT] mlat-client(3202): Server status: synchronized with 407 nearby receivers
[2025-05-28 17:27 CDT] mlat-client(3202): Aircraft: 10 of 19 Mode S, 60 of 79 ADS-B used
[2025-05-28 17:27 CDT] mlat-client(3202): Server: 0.0 kB/s from server 0.0kB/s TCP to server 2.8kB/s UDP to server
[2025-05-28 17:27 CDT] mlat-client(3202): Receiver: 567.3 msg/s received 267.9 msg/s processed (47%)
[2025-05-28 17:30 CDT] 1707786 msgs recv’d from dump1090-fa (2778 in last 5m); 1707786 msgs sent to FlightAware
[2025-05-28 17:35 CDT] 1710445 msgs recv’d from dump1090-fa (2659 in last 5m); 1710445 msgs sent to FlightAware
[2025-05-28 17:40 CDT] 1712948 msgs recv’d from dump1090-fa (2503 in last 5m); 1712948 msgs sent to FlightAware
[2025-05-28 17:42 CDT] mlat-client(3202): Receiver status: connected
[2025-05-28 17:42 CDT] mlat-client(3202): Server: 0.0 kB/s from server 0.0kB/s TCP to server 2.8kB/s UDP to server
[2025-05-28 17:42 CDT] mlat-client(3202): Receiver: 544.7 msg/s received 262.6 msg/s processed (48%)
[2025-05-28 17:42 CDT] mlat-client(3202): Aircraft: 8 of 17 Mode S, 60 of 90 ADS-B used
[2025-05-28 17:42 CDT] mlat-client(3202): Server status: synchronized with 436 nearby receivers
[2025-05-28 17:42 CDT] mlat-client(3202): Results: 13.8 positions/minute
[2025-05-28 17:45 CDT] 1715240 msgs recv’d from dump1090-fa (2292 in last 5m); 1715240 msgs sent to FlightAware
[2025-05-28 17:50 CDT] 1717289 msgs recv’d from dump1090-fa (2049 in last 5m); 1717289 msgs sent to FlightAware
[2025-05-28 17:55 CDT] 1719174 msgs recv’d from dump1090-fa (1885 in last 5m); 1719174 msgs sent to FlightAware
[2025-05-28 17:57 CDT] mlat-client(3202): Receiver status: connected
[2025-05-28 17:57 CDT] mlat-client(3202): Aircraft: 9 of 15 Mode S, 51 of 85 ADS-B used
[2025-05-28 17:57 CDT] mlat-client(3202): Server: 0.0 kB/s from server 0.0kB/s TCP to server 2.7kB/s UDP to server
[2025-05-28 17:57 CDT] mlat-client(3202): Receiver: 539.2 msg/s received 253.9 msg/s processed (47%)
[2025-05-28 17:57 CDT] mlat-client(3202): Server status: synchronized with 487 nearby receivers
[2025-05-28 17:57 CDT] mlat-client(3202): Results: 15.4 positions/minute
[2025-05-28 18:00 CDT] 1721396 msgs recv’d from dump1090-fa (2222 in last 5m); 1721396 msgs sent to FlightAware
[2025-05-28 18:05 CDT] 1723330 msgs recv’d from dump1090-fa (1934 in last 5m); 1723330 msgs sent to FlightAware
[2025-05-28 18:10 CDT] 1725392 msgs recv’d from dump1090-fa (2062 in last 5m); 1725392 msgs sent to FlightAware
[2025-05-28 18:12 CDT] mlat-client(3202): Results: 16.5 positions/minute
[2025-05-28 18:12 CDT] mlat-client(3202): Server status: synchronized with 405 nearby receivers
[2025-05-28 18:12 CDT] mlat-client(3202): Aircraft: 7 of 11 Mode S, 50 of 77 ADS-B used
[2025-05-28 18:12 CDT] mlat-client(3202): Server: 0.0 kB/s from server 0.0kB/s TCP to server 2.7kB/s UDP to server
[2025-05-28 18:12 CDT] mlat-client(3202): Receiver: 553.1 msg/s received 254.9 msg/s processed (46%)
[2025-05-28 18:12 CDT] mlat-client(3202): Receiver status: connected
[2025-05-28 18:15 CDT] 1727444 msgs recv’d from dump1090-fa (2052 in last 5m); 1727444 msgs sent to FlightAware
[2025-05-28 18:20 CDT] 1729577 msgs recv’d from dump1090-fa (2133 in last 5m); 1729577 msgs sent to FlightAware
[2025-05-28 18:25 CDT] 1731865 msgs recv’d from dump1090-fa (2288 in last 5m); 1731865 msgs sent to FlightAware
[2025-05-28 18:27 CDT] mlat-client(3202): Server: 0.1 kB/s from server 0.0kB/s TCP to server 2.7kB/s UDP to server
[2025-05-28 18:27 CDT] mlat-client(3202): Receiver status: connected
[2025-05-28 18:27 CDT] mlat-client(3202): Aircraft: 5 of 9 Mode S, 62 of 81 ADS-B used
[2025-05-28 18:27 CDT] mlat-client(3202): Receiver: 542.2 msg/s received 253.3 msg/s processed (47%)
[2025-05-28 18:27 CDT] mlat-client(3202): Server status: synchronized with 461 nearby receivers
[2025-05-28 18:27 CDT] mlat-client(3202): Results: 22.0 positions/minute
[2025-05-28 18:30 CDT] 1734053 msgs recv’d from dump1090-fa (2188 in last 5m); 1734053 msgs sent to FlightAware
[2025-05-28 18:35 CDT] logged in to FlightAware as user ExCalbr
[2025-05-28 18:35 CDT] multilateration data requested
[2025-05-28 18:35 CDT] my feeder ID is fc8e7018-5f0d-4180-43ca-0a8d9a6597d0
[2025-05-28 18:35 CDT] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 206.253.80.198:12659:1793188260
[2025-05-28 18:35 CDT] site statistics URL: https://flightaware.com/adsb/stats/user/ExCalbr#stats-24859
[2025-05-28 18:35 CDT] mlat-client(32221): Listening for Extended Basestation-format results connection on port 30106
[2025-05-28 18:35 CDT] mlat-client(32221): fa-mlat-client 0.2.13 starting up
[2025-05-28 18:35 CDT] mlat-client(32221): Input connected to localhost:30005
[2025-05-28 18:35 CDT] mlat-client(32221): Using UDP transport to 206.253.80.198 port 12659
[2025-05-28 18:35 CDT] mlat-client(32221): Route MTU changed to 1500
[2025-05-28 18:35 CDT] mlat-client(32221): Listening for Beast-format results connection on port 30105
[2025-05-28 18:35 CDT] mlat-client(32221): Input format changed to BEAST, 12MHz clock
[2025-05-28 18:35 CDT] mlat-client(32221): Beast-format results connection with ::1:30104: connection established
[2025-05-28 18:40 CDT] 1738245 msgs recv’d from dump1090-fa (2046 in last 5m); 1738002 msgs sent to FlightAware
[2025-05-28 18:45 CDT] 1740339 msgs recv’d from dump1090-fa (2094 in last 5m); 1740096 msgs sent to FlightAware
[2025-05-28 18:46 CDT] site statistics URL: https://flightaware.com/adsb/stats/user/ExCalbr#stats-24859
[2025-05-28 18:46 CDT] logged in to FlightAware as user ExCalbr
[2025-05-28 18:46 CDT] multilateration data requested
[2025-05-28 18:46 CDT] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 206.253.80.201:11035:1326048038
[2025-05-28 18:46 CDT] my feeder ID is fc8e7018-5f0d-4180-43ca-0a8d9a6597d0
[2025-05-28 18:46 CDT] mlat-client(1649): fa-mlat-client 0.2.13 starting up
[2025-05-28 18:46 CDT] mlat-client(1649): Listening for Beast-format results connection on port 30105
[2025-05-28 18:46 CDT] mlat-client(1649): Using UDP transport to 206.253.80.201 port 11035
[2025-05-28 18:46 CDT] mlat-client(1649): Input format changed to BEAST, 12MHz clock
[2025-05-28 18:46 CDT] mlat-client(1649): Route MTU changed to 1500
[2025-05-28 18:46 CDT] mlat-client(1649): Input connected to localhost:30005
[2025-05-28 18:46 CDT] mlat-client(1649): Listening for Extended Basestation-format results connection on port 30106
[2025-05-28 18:46 CDT] mlat-client(1649): Beast-format results connection with ::1:30104: connection established
[2025-05-28 18:50 CDT] 1742152 msgs recv’d from dump1090-fa (1813 in last 5m); 1741873 msgs sent to FlightAware
[2025-05-28 18:55 CDT] 1743963 msgs recv’d from dump1090-fa (1811 in last 5m); 1743684 msgs sent to FlightAware
[2025-05-28 19:45 CDT] multilateration data requested
[2025-05-28 19:45 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:45 CDT] site statistics URL: https://flightaware.com/adsb/stats/user/ExCalbr#stats-24859
[2025-05-28 19:45 CDT] adept reported location: 30.35743, -97.72322, 782ft AMSL
[2025-05-28 19:45 CDT] my feeder ID is fc8e7018-5f0d-4180-43ca-0a8d9a6597d0
[2025-05-28 19:45 CDT] logged in to FlightAware as user ExCalbr
[2025-05-28 19:45 CDT] 0 msgs recv’d from dump1090; 0 msgs sent to FlightAware
[2025-05-28 19:45 CDT] no ADS-B data program seen listening on port 30005 for 63 seconds, next check in 60s
[2025-05-28 19:46 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:46 CDT] multilateration data requested
[2025-05-28 19:46 CDT] no ADS-B data program seen listening on port 30005 for 10 seconds, next check in 60s
[2025-05-28 19:46 CDT] 0 msgs recv’d from dump1090 (0 in last 89m); 0 msgs sent to FlightAware
[2025-05-28 19:47 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:47 CDT] no ADS-B data program seen listening on port 30005 for 70 seconds, next check in 60s
[2025-05-28 19:48 CDT] piaware (process 430) is exiting…
[2025-05-28 19:48 CDT] update request complete
[2025-05-28 19:48 CDT] multilateration data no longer required, disabling mlat client
[2025-05-28 19:48 CDT] performing manual update, action: restart_piaware
[2025-05-28 19:48 CDT] restarting piaware. hopefully i’ll be right back…
[2025-05-28 19:48 CDT] manual update (user-initiated via their flightaware control page) requested by adept server
[2025-05-28 19:48 CDT] piaware (process 430) is shutting down because it received a shutdown signal (SIGTERM) from the system…
[2025-05-28 19:48 CDT] attempting to restart piaware using ‘systemctl --no-block try-restart piaware.service < /dev/null’…
[2025-05-28 19:48 CDT] no ADS-B data program seen listening on port 30005 for 3 seconds, next check in 60s
[2025-05-28 19:48 CDT] logged in to FlightAware as user ExCalbr
[2025-05-28 19:48 CDT] my feeder ID is fc8e7018-5f0d-4180-43ca-0a8d9a6597d0
[2025-05-28 19:48 CDT] multilateration data requested
[2025-05-28 19:48 CDT] adept reported location: 30.35743, -97.72322, 782ft AMSL
[2025-05-28 19:48 CDT] site statistics URL: https://flightaware.com/adsb/stats/user/ExCalbr#stats-24859
[2025-05-28 19:48 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:48 CDT] UAT support disabled by local configuration setting: uat-receiver-type
[2025-05-28 19:48 CDT] 0 msgs recv’d from dump1090; 0 msgs sent to FlightAware
[2025-05-28 19:48 CDT] performing manual update, action: restart_dump1090
[2025-05-28 19:48 CDT] attempting to restart dump1090..
[2025-05-28 19:48 CDT] dump1090 restart appears to have been successful
[2025-05-28 19:48 CDT] attempting to restart dump1090-fa using ‘systemctl --no-block try-restart dump1090-fa.service < /dev/null’…
[2025-05-28 19:49 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:49 CDT] no ADS-B data program seen listening on port 30005 for 64 seconds, next check in 60s
[2025-05-28 19:50 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:50 CDT] no ADS-B data program seen listening on port 30005 for 124 seconds, next check in 60s
[2025-05-28 19:51 CDT] site statistics URL: https://flightaware.com/adsb/stats/user/ExCalbr#stats-24859
[2025-05-28 19:51 CDT] multilateration data requested
[2025-05-28 19:51 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:51 CDT] adept reported location: 30.35743, -97.72322, 782ft AMSL
[2025-05-28 19:51 CDT] my feeder ID is fc8e7018-5f0d-4180-43ca-0a8d9a6597d0
[2025-05-28 19:51 CDT] logged in to FlightAware as user ExCalbr
[2025-05-28 19:52 CDT] 0 msgs recv’d from dump1090; 0 msgs sent to FlightAware
[2025-05-28 19:52 CDT] no ADS-B data program seen listening on port 30005 for 63 seconds, next check in 60s
[2025-05-28 19:52 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:52 CDT] multilateration data requested
[2025-05-28 19:52 CDT] no ADS-B data program seen listening on port 30005 for 10 seconds, next check in 60s
[2025-05-28 19:53 CDT] 0 msgs recv’d from dump1090 (0 in last 95m); 0 msgs sent to FlightAware
[2025-05-28 19:53 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:53 CDT] no ADS-B data program seen listening on port 30005 for 70 seconds, next check in 60s
[2025-05-28 19:54 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:54 CDT] no ADS-B data program seen listening on port 30005 for 130 seconds, next check in 60s
[2025-05-28 19:55 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:55 CDT] site statistics URL: https://flightaware.com/adsb/stats/user/ExCalbr#stats-24859
[2025-05-28 19:55 CDT] my feeder ID is fc8e7018-5f0d-4180-43ca-0a8d9a6597d0
[2025-05-28 19:55 CDT] multilateration data requested
[2025-05-28 19:55 CDT] logged in to FlightAware as user ExCalbr
[2025-05-28 19:55 CDT] adept reported location: 30.35743, -97.72322, 782ft AMSL
[2025-05-28 19:55 CDT] 0 msgs recv’d from dump1090; 0 msgs sent to FlightAware
[2025-05-28 19:56 CDT] no ADS-B data program seen listening on port 30005 for 64 seconds, next check in 60s
[2025-05-28 19:56 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:56 CDT] no ADS-B data program seen listening on port 30005 for 10 seconds, next check in 60s
[2025-05-28 19:57 CDT] 0 msgs recv’d from dump1090 (0 in last 99m); 0 msgs sent to FlightAware
[2025-05-28 19:57 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:57 CDT] no ADS-B data program seen listening on port 30005 for 71 seconds, next check in 60s
[2025-05-28 19:58 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:58 CDT] no ADS-B data program seen listening on port 30005 for 131 seconds, next check in 60s
[2025-05-28 19:59 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 19:59 CDT] no ADS-B data program seen listening on port 30005 for 191 seconds, next check in 60s
[2025-05-28 20:00 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 20:00 CDT] no ADS-B data program seen listening on port 30005 for 251 seconds, next check in 60s
[2025-05-28 20:01 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2025-05-28 20:01 CDT] no ADS-B data program seen listening on port 30005 for 311 seconds, next check in 60s
[2025-05-28 20:02 CDT] 0 msgs recv’d from dump1090 (0 in last 5m); 0 msgs sent to FlightAware
Here’s the storm that just blew past. Looks like another one is coming.
I found a similar post and followed instructions. Looks like the dongle is fried.
pi@piaware:~ $ sudo apt install stl-sdr
Reading package lists… Done
Building dependency tree… Done
E: Unable to locate package stl-sdr
pi@piaware:~ $ sudo systemctl stop piaware dump1090-fa dump978-fa
pi@piaware:~ $ rtl_test -t
No supported devices found.
On a whim I decided to swap the two mini USB ports (traded the power supply for the dongle connection. Now it’s working.
Well, I had one good day. Then on Friday, although I was getting messages, the levels were low. See graphs for both my feeders here.
I bought another blue feeder, and it seems to have made no difference. Yet there is a clear change on the day of the hailstorm. I disconnected everything, cleaned the connections at the RPi end, then reconnected, making sure everything was firm. It didn’t seem to make a difference. The other option is the antenna end. I’m using a FA antenna. It has a larger connector than at the RPi end. I had to climb up to the roof to inspect it. It seems firm. I was going to unscrew it and screw it back in, but I didn’t bring any tools with me up to the roof, and I was unable to unscrew it by hand. I wonder if something got jarred loose inside the antenna housing. Is there a diagram of what it’s like inside? The first image shows the messages received from May 13 until today. May 29 is when the storm hit. The second image shows a similar graph from my other feeder. The 250+ miles count has also dropped from a few dozen on average to zero.
Never mind about the inside of the antenna. I found pictures on the forum.
Are all of your outside coax connections well weatherproofed?
The one at the base of the antenna (9 year-old antenna btw) is just what comes with the Flightaware antenna. It has a large screw-in housing that seems to protect the inner real connector. I’ve assumed this design was intended to be weatherproof. I added nothing extra on that end. The other end, by the RPi is sheltered, but still outside. Should I be doing something else at the antenna end? Edit: what I stated is false. The cable is one I bought last year.
Doing a search I see it’s recommended to seal the connection with self-amalgamating tape or something. I have not done that. Perhaps I’ll bring the antenna down, take the connection apart, clean thoroughly and tape it up when I next have some time. If any storm could introduce water infiltration it was that one. We got and inch and a half of rain in 10 minutes. There was a microburst right over my location.
