I have a pi3 I use for ham radio, and it has a bunch of stuff I need (especially the kernel).
I tried version 3 on my pi2 but it won’t work with my wifi dongle, so that’s out.
So, I built the piaware_builder and it is installed and checking in all right. I used the /etc/piaware.conf for config.
It checks-in with flightaware so that’s good, but no beast. So I built the beast-splitter and figured the piaware would start it up internally. I guess not. So I tried the:
If you are building your own image then you will have to do it yourself; this type of configuration is something that is done by the support packages that are present on the sdcard image only.
You could try building/installing the piaware-support package, but I can’t provide support for that and be aware that it will go and stomp on your configuration because it is expecting to be run on a sdcard image
If you are getting port conflicts from beast-splitter that means you have something else running that you didn’t mention (piaware itself does not listen on any ports)
