When I bought the FlightAware Pro Stick Plus I assumed that it would come with something other than the plastic bag that it came in!
Where can I find software AND step by step instructions on how to get it to work on my Mac?
I have installed CocoaRTLServer 2.0 and it CAN find the USB stick so the stick IS working, BUT everything that I have followed on the Internet just keeps coming back saying that it cannot open the device!
So, where can I get clear, concise step by step instructions on how to get it to work on my Mac?
It’s meant for use with a Raspberry Pi.
Not sure if there ADS-B reception applications ported for OS X, but i don’t think so.
There is some ADS-B decoding software around for Windows.
The typical dump1090-fa used on the Raspberry Pi also works on Debian or Ubuntu on x86 PCs.
The typical use case is that you connect to a Raspberry Pi that you run 24/7.
Obviously that’s Flightawares intent as you can read on the build page.
Supporting other platforms costs lots of money, plus most computers don’t run 24/7.
You may be able to build dump1090-fa from source; at one point it would build under OS X. But that’s not maintained or tested so it may need some TLC to get it working. You’ll need to sort out a build environment and build libusb / librtlsdr at a minimum.
You have to configure it to match what Coco1090 is expecting. The directions should be on his site.
If you installed any other SDR SW, it could be claiming the device, so only you could know what that might be.
BTW, you can pretty much run all the SDR stuff on the Mac, Flight Air Map, VRS, ACARS, etc, but you have to install homebrew or MacPorts and build a bunch of stuff yourself - Not for the non-programming folks.
Much easier to buy a super cheap raspberry pi,and burn the piaware image to an SD card, and get an instantly working set up.
You can run whatever you like on the Mac. The problem @pforkes has is to find a suitable demodulator that can talk to the Pro Stick Plus, perhaps a dump1090 variant like dump1090-mac, a suitable local viewer for the data and a process for feeding FlightAware. That’s a lot of work researching and gluing things together.
If the goal is to get it up and running, then, as @wiedehopf suggested, a Raspberry Pi is the way to go. Grab PiAware, write it to a card. Instant results.
The FlightAware Pro Stick is inserted into a USB drive on my Mac Mini and if I run CocoaRTL Server 2.0 it shows the device name “ Generic RTL2832U (e.g. Hama nano) ” which suggests (to me) that the device is being recognized by the operating system as having the name " Generic RTL2832U (e.g. Hama nano) "
I have downloaded SDRplay_RSP_API-MacOSX-2.13.2.pkg and run the installer program to completion.
This is definitely not showing anything to me that says ’this driver is installed and is working’ .
If you can suggest anything that might help me to get my FlightAware Pro Stick to be accessible for use on may Mac mini then it would very much be appreciated.
On a Mac, the following command will do reception of commercial wide-band FM signals. This assumes that the sox package is installed by command: port install sox
