I have just done all of that and I am STILL getting:
./rtl_test
Found 1 device(s):
0: Generic RTL2832U (e.g. hama nano)
Using device 0: Generic RTL2832U (e.g. hama nano)
Failed to open rtlsdr device #0.
./rtl_test
Found 1 device(s):
I tried thisâŚ
port install sox
andâŚ
zsh: command not found: port
GOT IT!!!
After recompiling it the symlink (?) did not update. I deleted that and booya!
Thank you! Now I get to wait 24-hours for my blood pressure to go downâŚ
Good work! Youâve learned from it as well.
Bit trollish there.
That is why I hate Mac and iPhone. Both are too restrictive, although otherwise these are a good computer/phone.
Not sure why youâre resurrecting this after three years, but anyway my 2 cents â on another thread, I mentioned that I couldnât get dump1090-fa to compile correctly on the latest macOS (Ventura). However I previously compiled it and had it running along with the local map display on macOS Monterey about a year ago. Course it didnât have piaware and feed FlightAware, it was just for local display. But why would you want to use a desktop/laptop/whatever to run 24/7 considering the power consumption? Thatâs why we have things like Raspberry Piâs.
As far as support for an RPi with piaware, you can run ssh on a Mac from the terminal (you donât need PuTTY), you can edit the micro sd card boot partition on a Mac, etc the same as with Linux or Windows. So, no limitation there.
Because thatâs a Linux SD card. You canât do any of that in native MacOS, you canât even see the pictures on a phone, like you can see when connect an Android phone to a PC. You need a supplement junky software made by Apple for Windows to even attempt that, and it is buggy and slow.
