I am attempting to connect the flightaware pro plus receiver to the Rasperry pi using a USB/ethernet extender. It basically uses an ethernet cable to tie both ends of the USB. The receiver works fine when it is directly plugged into the Raspberry pi. However, I am getting no hits when it is connected via the extender. The url screen shows the radio in amber status (the message is ‘Connected to receiver but no recent data seen’). The Raaspberry pi also shows the radio as connected under lsusb:
lsusb:
Bus 001 Device 013: ID 0bda:2832 Realtek Semiconductor Corp. RTL2832U DVB-T
This means that the extender is doing its job correctly - the USB device is being recognized correctly. But I am puzzled why there is no signal. The antenna and location are identical under both cases.
Any suggestions or tests I could run to figure out the problem would be appreciated.
I should add that this is a powered extender, fed from a different 5V supply.
Thanks for that suggestion. I ran rts_test, and this is what I got.
With the transmitted plugged directly to the Raspberry. System works and reports ADSB traffic.
pi@piaware:~ $ sudo rtl_test -t
Found 1 device(s):
0: Realtek, RTL2832U, SN: 00001000
usb_claim_interface error -6
Failed to open rtlsdr device #0.
With the USB extender. No traffic being reported.
Found 1 device(s):
0: , , SN:
usb_claim_interface error -5
I am unsure what to make of these results.
I should add that the extender I am using is advertised to work on USB 1.0 and USB 2.0, but not USB 3.0. Could that be a possible reason? But I can’t imagine that the ADSB data really needs the data rates from USB 3.0.
I searched a bit regarding the code -5. this pointed to a libusb error and not librtlsdr as I thought initially.
so I found FWIW all relevant error codes here and are as follows:
enum libusb_error {
LIBUSB_SUCCESS = 0,
LIBUSB_ERROR_IO = -1,
LIBUSB_ERROR_INVALID_PARAM = -2,
LIBUSB_ERROR_ACCESS = -3,
LIBUSB_ERROR_NO_DEVICE = -4,
**LIBUSB_ERROR_NOT_FOUND = -5,**
LIBUSB_ERROR_BUSY = -6,
LIBUSB_ERROR_TIMEOUT = -7,
LIBUSB_ERROR_OVERFLOW = -8,
LIBUSB_ERROR_PIPE = -9,
LIBUSB_ERROR_INTERRUPTED = -10,
LIBUSB_ERROR_NO_MEM = -11,
LIBUSB_ERROR_NOT_SUPPORTED = -12,
LIBUSB_ERROR_OTHER = -99
Error codes.
Most libusb functions return 0 on success or one of these codes on failure. You can call libusb_error_name() to retrieve a string representation of an error code or libusb_strerror() to get an end-user suitable description of an error code.
Enumerator
LIBUSB_SUCCESS
Success (no error)
LIBUSB_ERROR_IO
Input/output error.
Invalid parameter.
LIBUSB_ERROR_ACCESS
Access denied (insufficient permissions)
No such device (it may have been disconnected)
**Entity not found.**
LIBUSB_ERROR_BUSY
Resource busy.
Operation timed out.
Overflow.
LIBUSB_ERROR_PIPE
Pipe error.
System call interrupted (perhaps due to signal)
LIBUSB_ERROR_NO_MEM
Insufficient memory.
Operation not supported or unimplemented on this platform.
LIBUSB_ERROR_OTHER
Other error.
rtlsdr_write_reg failed with -1
Resetting device…
rtlsdr_write_reg failed with -4
rtlsdr_demod_write_reg failed with -4
rtlsdr_demod_read_reg failed with -4
rtlsdr_read_reg failed with -4
No supported tuner found
Enabled direct sampling mode, input 1
Supported gain values (1): 0.0
WARNING: Failed to set sample rate.
I should add that the ethernet cable is only 3 ft long, for this test. The other end of the USB is powered from a 5V supply (also a short length lead from the outlet). I swapped out the power supply and got the same results.
One thing I’d like to know is, does the flightaware pro plus radio require USB 3.0?
OK thanks. That seems to suggest the USB extender might be faulty. However, this is brand new. The make/model is IOGEAR GUEC62 USB 2.0 BoostLinq Ethernet - 164ft. I guess I’ll buy another model and try it again.
the datasheet says for Linux, Unix and other USB supported systems, additional drivers and support may be needed, so best to give their support a call and explain the problem.
curiosity, have you tried without powering the remote unit ?
USB 2.0 BoostLinq Ethernet - 164ft (TAA Compliant)
The kit includes a power supply and two dongles. The local dongle connects directly to your computer and the remote dongle connects directly to your USB device. These two dongles are interconnected with Cat5, Cat5e, or Cat6 cabling (not included) to extend the USB device any distance desired- up to 164 feet (50 meters). The GUCE62 is simple to set up and requires no additional drivers to install.
Operating System Requirements
Windows
Windows Vista®, Windows® 7, Windows® 8, Windows® 8.1
Mac
Mac OS X v10.3.9
Linux
Linux Kernel
Chrome OS
Google Chrome OS?
USB Specification USB 2.0
Cable Connections
Input Transmitter: USB A Male; Receiver: RJ45
Output Transmitter: RJ45; Receiver: USB A Female
Transfer Rate Up to 480Mbps
Cable Length Transmitter: USB cable 1ft (included); Receiver: Cat 5, Cat 5e or Cat 6 cable (not included) up to 164ft (50m)
Cable Distance Maximum cable distance from Transmitter to Receiver: 164ft (50m) Cable Type Ethernet Cat 5, Cat 5e or Cat 6 required for connection between receiver and transmitter.
I suggest that to clear USB 2.0 / 3.0 doubt, if you have a small (say 6 ft) USB 2.0 extender, then use it to connect Pro Stick to Pi. This test will clear your doubt.
When trying to get a good rooftop solution, I tried several of the USB-over-CAT5 cables, only to be disappointed with each one. I bought one of the 10M (32ft) BlueRigger cables a couple of years ago and had success between an Orange Pi PC and an FA ProStik. After buying a second cable, was able to string them together and still have success.
There is also a 20M (64ft) version that has the same appearance but without a brand name, that has two repeaters on it that also works, although combining a 20M and a 10M doesn’t work.
Eventually, settled on PoE for the long distances.
I use two USB2 extenders (one of them is from a Logitech keyboard receiver) on my receivers because… I cannot shove two receivers in one Pi, don’t have the physical space, they are too “fat”.
So, USB2 definitely not an issue.
