I’m getting lots of targets (source TIS-B) which contain no valid identification. A screenshot shows one aircraft highlighted with what appears to be a hex ICAO ID code prefixed by tilde ‘~’ as follows: ~2A0A0E. This is not a valid US ICAO aircraft registration number. Notice in the screenshot that every aircraft using this symbol decodes the same way.
So TIS-B comes from the ground station - an airborne receiver is supposed to use it to display potential traffic conflicts. Without an ID (either ICAO or Registration) how does the airborne receiver correlate the TIS-B with other targets it sees? I’m confused. Here is a typical TIS-B that I’m capturing:
*952a0666993c0190200660854c43;
CRC: 000000
RSSI: -5.9 dBFS
Score: 1400
Time: 1292084.83us
DF:18 AA:2A0666 CF:5 ME:993C0190200660
Extended Squitter (Non-Transponder) Airborne velocity over ground, subsonic (19/1)
Other Address: 2A0666 (TIS-B, other addressing scheme)
Geom - baro: 2375 ft
Ground track 180.0
Groundspeed: 128.0 kt
Geom rate: 0 ft/min
NACv: 7
It doesn’t seem to have any way to correlate with a known target. What am I missing? Is this the equivalent of a primary only target?? During a 30 second dump I saw three distinct targets (based on “Other Address” value.)
Yes, something like that. It’s a radar track with the ground infrastructure doing the correlation; it might be a primary-only or A/C target. The airborne receiver isn’t expected to correlate it with anything else, it’s just a traffic notification.
Does anyone have a copy of the relevant TIS-B specs I could look at? Seems they are locked behind a gov’t sponsored paywall called the RTCA and available at HUGE prices, like four digits.
Welcome to the wonderful world of expensive aerospace specifications
There’s no spec I know of that describes how the data underlying TIS-B is generated; it’s just whatever the FAA does. Presumably some of it will be piggybacking off the back of ASDE-X / ASSC etc.
