hello flightaware
about a few days ago report the not up load, i m use HDMI see the flightfeeder system, found the ads-b system no have serial number
P.S. my flightfeeder update to 6.2 the no have serial number
I don’t knww what you mean by serial no:
if I go to my site page
flightaware.com/adsb/stats/user/PeterHR
I see
http://s12.postimg.org/68rxbmxl9/Snap16.jpg
the MAC addrees is used as the ident for the site
this can be seen here
pi@raspberrypi ~ $ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:1e:5d:70
inet addr:192.168.3.12 Bcast:192.168.3.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:74142282 errors:0 dropped:0 overruns:0 frame:0
TX packets:82266855 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1189385423 (1.1 GiB) TX bytes:3266936919 (3.0 GiB)
(You have blanked this info out in the photo you posted)
It’s a flightfeeder, not a piaware system; each FF has a unique serial number.
sorry, i m equipment a Flightaware the ADS-B, no PiAware, but thank you help
yep, i know, but my flightfeeder update to 6.2, no have serial nmuber
Check the sticker on the back of your flightfeeder box.
yes, the flightfeeder box have number
Hi,
We are working on fixing this issue for you.
A case has been assigned on your behalf (Case #51377). Someone will reach out to you shortly.
Your patience is appreciated.
Best regards,
Paul
We found the bug on the server side that prevented a few FlightFeeders from connecting. Boxes without a serial should now be able to connect and get their serial numbers.
The fix should be live in a few hours.
