perfect - you did it - thank you
only complain - title is somewhat shy and misleading - my suggestion: ‘MY BEST ADS-B HOW-TOs from mgunther’ and then made sticky on top from fa staff
(Reading database … 78986 files and directories currently installed.)
Preparing to replace piaware 2.1-3 (using piaware_2.1-3_armhf.deb) …
Unpacking replacement piaware …
dpkg: dependency problems prevent configuration of piaware:
piaware depends on tclx8.4; however:
Package tclx8.4 is not installed.
piaware depends on tcllib; however:
Package tcllib is not installed.
piaware depends on tcl-tls; however:
Package tcl-tls is not installed.
piaware depends on itcl3; however:
Package itcl3 is not installed.
dpkg: error processing piaware (–install):
dependency problems - leaving unconfigured
Processing triggers for man-db …
Errors were encountered while processing:
piaware
But these steps would not complete
sudo apt-get install -fy
This will enable automatic and manual (web-based, via your request) PiAware software updates. Set to 0 for the opposite (default).
sudo piaware-config -autoUpdate 1 -manualUpdate 1
It always came back with something is missing
I have my original mut dev ver on a 32 GB card with the piaware 2.1.2 and everything set up fine with his original post above but with 2.1.3 i could not get install work for nothing I think I tore all my hair out trying to figiure what i did wrong…and backed up…but was trying to make some fresh installs with 16gb cards so I could take them to my brothers place
