Does this use WebGL? Can it be made to do it?
Curious, why do you need that?
Geoff
This way the map uses less CPU and I can run it on a lighter CPU system.
tar1090 uses WebGL (if is enabled in the specific browser).
Not a “need” per se…
WebGL browser test:
http://get.webgl.org/
I do run mine on a Zero and CPU is around 50% Temperature just below 50c with room temperature around 18-21
Any viewing is done remotely via local network so I don’t view the data on the Pi itself, your link showed the spinning cube but that relates to my laptop, the ADS-B software is running on the Pi
Geoff
