SearchBirdseyeInFlight: "diverted" error
Hello,
I’m trying to get a list of all flights diverted to KBOS currently in the air. My query:
https://flightxml.flightaware.com/json/FlightXML2/SearchBirdseyeInFlight?howMany=15&offset=0&query={= dest KBOS} {true inAir} {true diverted}
The query works perfectly until I add the {true diverted} parameter, then I get the following error message:
can’t read “uniqueLine”: no such variable
I’ve checked with {true diverted} as the only parameter, and I get the same error message, so I know it’s not because there are no results (which shouldn’t return an error message anyway).
Am I missing something? Any suggestions?
Thanks!
It appears we have a bug with SearchBirdseyeInFlight when there are no results that match the query. That error is happening because of that. I’ve opened a bug, but you can interpret that error as no data matches the query.
Well, I just checked via
https://flightaware.com/live/diversions.rvt
that there are multiple flights diverted and currently in the air, and my query
is still returning that error. It seems to me that there should be some results, right?
I see the error message has been fixed to show “no data available” instead of “can’t read ‘uniqueLine’: no such variable,” thanks for that.
Any idea when the SearchBirdseyeInFlight request will be fixed to show diverted flights when the query is “{true diverted}”? My request is showing no results, but your live diversions page shows many. That is the data I am trying to access.
I appreciate your help!
