I tried, but my orange pi don’t show up in my network, looks like it didn’t boot with bullseye. It only connects to my lan with the jammy running on it
It is not buildidng dump978, it s building faup978
As piaware is used to feed both 1090 and 978 data to Flightaware, two uploders (faup1090 ad faup978) are it’s inegral part. The build process builds both uploaders
Okay, that really worked.
I was able to reactivate my feeders, everything works fine and great now, but I really don’t know what I did different from the other time that I’ve tried.
I wasn’t able to compile the program tho…
After search a lot I found the repository link to the armh version, it wasn’t easy to find.
Where can I find those links more accessibly, it would help me and saved a lot of time.
when I said that I wasn’t able to find the repository link to install the armh version, I was refering myself to the FR24 armh version (which is super unfriendly to any kind of support, and I still don’t know how to find the repository links).
I tried to follow these suggested path (PiAware - dump1090 ADS-B integration with FlightAware - FlightAware). Well, at the first time I manage to install the software with no errors, but, I couldn’t make the software link to my user. The status on pi showed that the connection was stablished but I had “offline” status in the service. I formatted the SD and tried to install everything again, without success one more time, It couldn’t connect to my previously created feed. Then I started chatting with the support team, which instructed me to do the same thing that I have done one more time (re-flash the SD card). When I was about to do it, I saw that the Unique Identifier wasn’t the same as my feeder, so, I just changed the code to the one that was on my feeder and it started to work again.
