Err 404 on apt update
Err:8 http://flightaware.com/adsb/piaware/files/packages jammy Release
404 Not Found [IP: 172.105.15.144 80]
Err:1 http://apt.armbian.com jammy InRelease
502 Bad Gateway [IP: 2602:fea7:e0d:1001::12 80]
Is somebody facing the same issue than me?
We don’t provide binary packages for that distribution, you’ll need to build packages from source yourself (or tell it to use the appropriate debian distro name if you can use the standard 32-bit arm raspbian/debian packages)
STEP-1
sudo rm /etc/apt/sources.list.d/flightaware-apt-repository.list
sudo apt update
STEP-2:
Run the bash-scripts at following Github site.
These scripts will build latest version of piaware, dump1090-fa, dump978-fa, and piaware-web using source-code from Flightaware.
https://github.com/abcd567a/piaware-ubuntu-debian-amd64/blob/master/README.md
Thank you sir,
big fan here.
Everything is working just fine now
thank you again!
