Hello,
Been banging my head all day on this and reading around the community but no solutions thus far.
I ham encountering an issue with configuring PiAware on a RPI 5 specifically it seems dump1090 dows not seem to be working and I see the message:
I tried running it in interactive and also no data is being pulled in..
I tried the same RTL-SDR V4 dongle on a ubuntu PC and on a Windows PC and Dump1090 works fine, I can see the data on the screen.
Using SDR++ on the same RPI’s works fine..
I downloaded the PiAware image also the same issue on two different RPI 5.
I have used very good power supplies, but the issue persists.
pi@PiAware:~ $ piaware-statusPiAware master process (piaware) is running with pid 2193.PiAware ADS-B client (faup1090) is running with pid 2231.PiAware ADS-B UAT client (faup978) is not running (disabled by configuration settings)PiAware mlat client (fa-mlat-client) is not running.Local ADS-B receiver (dump1090-fa) is running with pid 2218.
dump1090-fa (pid 2218) is listening for ES connections on port 30005.faup1090 is connected to the ADS-B receiver.piaware is connected to FlightAware.
Aug 02 21:22:53 PiAware dump1090-fa[1864]: rtlsdr: tuner gain set to 49.6 dB (gain step 28)Aug 02 21:23:03 PiAware dump1090-fa[1864]: adaptive: available dynamic range (45.0dB) >= required dynamic range (30.0dB), continuing upward scanAug 02 21:23:03 PiAware dump1090-fa[1864]: adaptive: changing gain from 49.6dB (step 28) to 58.6dB (step 29) because: probing dynamic range gain upper boundAug 02 21:23:03 PiAware dump1090-fa[1864]: rtlsdr: tuner gain set to about 58.6 dB (gain step 29) (tuner AGC enabled)Aug 02 21:23:13 PiAware dump1090-fa[1864]: adaptive: reached upper gain limit, halting dynamic range scan here
Any ideas or guidance?
Thanks!
