Tried that, didn’t work. First off “curl” didn’t work, some quick googling showed my how to install curl, that didn’t work. Another google said I could subsitute “curl” with “wget” so i did that and got this -
pi@piaware:~$ wget dataplicity.com/i2by503v.py | sudo python
sudo: python: command not found
–2017-07-24 19:00:03-- dataplicity.com/i2by503v.py
Resolving dataplicity.com)… 192.155.88.83, 45.79.135.145, 2600:3c03::f03c:91ff:fee9:3231, …
Connecting to dataplicity.com)|192.155.88.83|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 24065 (24K) [text/x-shellscript]
Saving to: ‘i2by503v.py.1’
i2by503v.py.1 100%=====================>] 23.50K --.-KB/s in 0.05s
I don’t think it worked, not getting past the code copy/paste page on the dataplicity website. No clue what I’m doing, just trying to follow directions.
Check again the internal IP (of the FlightFeeder!!) and external IP. Forward external IP port 8080->Internal IP port 8080
Ask us to check the address, in case your phone ISP blocks that.
Okay, got the internal and external but the port forward page on my router doesn’t have any of that. It asks for an IP to forward and then what application to forward. That’s it. Nothing under “application to forward” means anything to me so I specific it as 8080. But again there’s only one IP to enter.
About a zillion ports. There are listings for pop3 and other stuff. Web server is right at the top. So I selected the piaware from the IP list and webswrver from apps, it defaults to port 80 and can’t be changed.
Okay. Went and did the port forwarding for the piaware (it’s 192.xxxx) IP address and the web server port 80. Checked at the port check website and it said the port was open. I deleted the port forwarding and yup, showed closed.
But it still doesn’t work. I try the IP address from my iPhone, plain, port 80 and port 8080 and just keep getting network connection lost message.
FlightFeeders are two types, Blue & Orange.
I dont know what is inside Blue one.
The orange one has a RPi+Pro Stick inside, so apparently web access should be same as for RPi.
I dont have any FlightFeeder, so I cannot try and tell you with surety. You have to try it yourself.
