Easy things to try.
And if you used common sense reading the commands found on google (one says install the other has reinstall in it … well …)
You just try until it works or everything is broken.
It’s that simple.
You could also read lots of google results on how the package management system works and actually understand what each option does.
There is also
I used the same scripts and works well. I used a second Pi that I use for antenna testing and the data isnt shared. I found Read ADSB works quite well for what I am doing.
I love the simplicity of getting this thing set up without the involvement of any FA repository or anything else. Just a local map, nothing else i need for that
I started from scratch. Installed Fr24 and Piaware.
Installed dump109-fa, readsb and your latest Airspy-conf and Graphs1090 as well.
Took me a few extra installations to get everything running smoothly.
Left the options as provide by you as default.
Will try different settings later, still reading the thread. Have to invest some time, as due to personal circumstances I only could start reading last sunday, so have a lot of catch up to do.
