ADSB Receiver Project Uninstall
Need help with the ADSB Receiver Project. After installing OpenSky and RadarBox24, the ADSB Receiver Project graphs stopped collecting and/or displaying data.
I tried re-installing it a number of times, but still no go. I cannot find instructions to completely uninstall it, so that I can start from scratch.
While on this topic… how do I revert back to the native Dump1090-fa skyview, that is, outside of the ADSB Receiver Project frame.
Thanks.
Re-imaged the sd card. Piaware only now.:smiley:
That is what I always do whenever I want to uninstall adsb-project web portal. :rofl:
Yep…I gave up after about an hour of searching and trying things out. I thing I have all the credits for a phd in re-imaging ADS-B SD cards. :smiley:
The FA image is so nice, you can do ALL the config on a Windows PC, before reaching for the ladder to swap cards in the RPi. Well done Flightaware!!
Prepared the new antenna location. Just waiting for replacements U bolts, as I lost the ones included with the FA antenna. It’ll only be about a couple of feet higher, but outdoors.
Enough with trying out different feeders… for now.:grinning:
Me too :smiley:
:+1: :+1: :+1: FULLY AGREE
Not Me. Happily feeding:
  1. Flightaware
  2. Planefinder
  3. Flightradar24
  4. Adsbexchange
  5. Radarbox24
  6. OpenSky-network
This is the one I want to try next, but my second Pi has been re-deployed. I’m thinking about purchasing another one.
All feeders on the same Pi?
I see ADSBHub is not on your list. Why not?:grinning:
YES
Very difficult site to navigate & register/setup. Got fed up and quit.
As you don’t have adsb-receiver web portal / graphs, consider installing ModeSMixer2 which can provide some graphs & plots locally on your PI, WITHOUT interfering with SkyView or any other data feeder:
https://sea1.discourse-cdn.com/flex019/uploads/flightaware/optimized/2X/b/bbbdd835fcf2a4aa28686322cc67cb7fd5ddb2e6_1_280x500.jpg
My first impression was the same, so I did not try.
I’ll have a look, thanks.
Tried installing ModeSMixer2. All fine until step 8:
cd mm2
./mm2.sh & disown
it says:
./modesmixer2: error while loading shared libraries: libssl.so.1.1: cannot open shared object file: No such file or directory
I don’t know enough to proceed.
Seems you have downloaded wrong version of ModeSMixer2. It has to be matched with Raspbian version.
If you are installing on Piaware image ( which is Jessie), then you have to download and unzip following:
#Remove existing content of folder mm2
#Command below will NOT delete file mm2.sh
#It will delete only downloaded+unzipped files
#You will not have to create file mm2.sh again
sudo rm mm2/mode*
#Check that all files except mm2.sh and LICENCE.MIT are removed
ls mm2
LICENSE.MIT  mm2.sh
#Download proper file for Piaware image (Jessie)
sudo wget -O mm2/modesmixer2_rpi2-3_20170924.tgz "https://www.dropbox.com/s/fm8zclxxq0kg8u4/modesmixer2_rpi2-3_20170924.tgz?dl=1"
#Move to folder mm2
cd mm2
#Un-zip new downloaded file
sudo tar xvzf modesmixer2_rpi2-3_20170924.tgz
#Try manual run (step 8)
./mm2.sh & disown
Perfect “diagnosis”. I downloaded the Strech version. U da Man!!!:joy:
The ModeSmixer2 pages are nice. The same as the ModeSdeco2 I tried in the past.
Edit:
This is great @abcd567. I had heard about ModeSmixer2 before, but always in the context of mixing feeds, and/or converting them from one type to another.
Looks like my search for the “Holy Grail” is almost complete. All I need now is “easy” export and logging capabilities, like some of the packages available to visual plane spotters.
