I had a faulty feeder and fixed it successfully. I can see planes in my local 192.168.x.x:8080 just fine. I did re-register my unit number 1120 twice but no stats are recorded under my profile’s stats.
Look at the tag on the bottom of the receiver and write down the mac address.
If your modem/wireless access point has View Clients look for the mac address of the receiver in this list. It may also be identified as Flight Feeder. If it is found it is possible for the receiver to upload to the internet.
If you are connecting to the internet through a network computer’s ethernet ports and wireless all of these have to be bridged and only work if that computer is on 24/7.
The IP of the bridge can be set automatic or to an IP of your choosing. I prefer to assign this bridge an IP whose range is determined by your modem/wireless port. If the receiver is connected to an ethernet port going into that bridge select automatic and for the DNS the IP address of the modem/wireless. From your quote above 192.168.1.1 would be the DNS address to point to IVP4/properties.
Thanks a lot. My feeder is connected directly to the modem. I can access it locally and I can see planes just fine but it seems it is not connected to FA for unknown reason. So it does not upload any recorded data to FA so far.
I tried to access the unit both direct and remotely using ssh and connection was refused in both cases. I think that is because the OS of FA feeder is a bit different. Can you please provide instructions for accessing it?
If I connect to HDMI TV, how can I force going to command line interface instead of GUI during booting?
Hi there. We need to “bless” the flightfeeder after it is restored from an image. It’s a process that generates a new key pair on the flightfeeder and retrieves the public key. I’m planning to provide a way for people to trigger reblessing themselves in the near future.
Anyway right now 1120 does not seem to be online so I can’t rebless it. If it’s up then something else is wrong.
FYI I had this problem as well and had to fix mine. The solution was to copy the feeder ID into piaware.conf, and also restore the files from /var/cache/piaware if you have them.
If you don’t, they are pretty easy to recreate
The feeder_id is a file that contains the feeder id in it, nothing else, just the feeder id. It looks like a uuidgen string and you can find all these values in your piaware dashboard.
The file called location contains two lines. The first is the latitude and the second is the longitude.
Because I am in the western hemisphere, the longitude line begins with a -
The location.env file contains
PIAWARE_LAT=“nn.nnnnn”
PIAWARE_LON=“-nnn.nnnnn”
PIAWARE_DUMP1090_LOCATION_OPTIONS=“–lat nn.nnnnn --lon -nnn.nnnnn”
There may be some dump978 options if you use that, I don’t have dump978 running. Hope this helps. Restart piaware and dump1090-fa system services after updating these and you’ll be good to go.
