I previously had a Pi running for many years and it recently stopped working.
I re-wrote the new piaware image from the guide here - the onlny “extra” thing I did was creating an empty ssh file in the root of the drive to enable ssh to the pi.
I also edited the config file with my wifi ssid and password (I see it connected when looking at my router as well)
I am able to see the Pi when visiting it’s IP address but I get all red with “PiAware doesn’t appear to be running!”
Is that guide/image still up to date or am I doing something incorrect?
EDIT:
When logging into my router I see two “piaware” IP leases…
192.168.1.129 - Old (why is it showing?)
192.168.1.225 - New
The new address was claim-able but also does not have MLAT or 1090 enabeled and doesn’t show my area/location on the map and also shows no flights.
I didn’t manually set it to the old one…I think it may have assigned me a new one…where/how am I able to find the old one? I only saw it for a moment on the claim page that I had two associated with my account. The two piaware hosts is confusing unless the SD Card re-write didn’t fully wipe something…
Based on above post by @obj, if you click following link, while logged in to your FA Accoun, and replacing FEEDERID by the long UUID assigned to ANY of your feeders, you will see following list. To claim & include in this list the newly created UUID and its assigned SITE number, you will have to click following link after replacing FEEDERID by the newly created receiver’s UUID.
To preserve my old stats do I have to use the old site information? I was able to successfully see the list and claimed my newly created site that was generated from re-writing the SD card.
I followed this post using my oldest siteID and restarted piaware but I still seem to be having some sort of issue…
On the /skyaware I’m not located in Italy and it seems like something isn’t wired up properly…
Most likely the location (latitude and longitude) is not configured / incorrectly configured.
To check/set your location settings, while loggedin to your FA account, go to your My-ADSB page, and open settings page by clicking the gear icon, and set location there.
So, I went to check and it looked like piaware was down. I manually restarted it, updated the location information, and upon checking the IP address the location has not been updated and the log shows nothing.
Is that potentially because I changed the feeder-id on my pi to the OLD site-id (to try to preserve site data/stats?)
EDIT - When checking the UUID on my user account page shows my 2nd oldest site-id (not my oldest or my newest) - I tried updating to the UUID from my profile to see if it fixed it…it did not.
In your screenshot, the airport associated with 274226 is shown as KCAK
The ICAO code KCAK corresponds to the Akron–Canton Airport located in Green, Ohio, USA. This means you have set the latitude and longitude of Ohio, USA, and not of Italy.
Please issue following command which will reveal your latitude and longitude setting at your My-ADSB page.
@kzisme
The dump1090-fa did NOT find the dongle and failed.
Unplug and replug the dongle firmly, and restart dump 1090-fa. If the dongle is plugged using a USB cable, remove it and plug the dongle directly into RPi.
Please also issue following commands and post output of 2nd and 3rd commands.
I have had the orange pro stick since ~2018 or whenever I first started feeding all on this same Pi - no USB cable. Do these eventually go bad? I ran both those commands and also tried both USB ports on the board and same result:
