Folks - I have found cron-apt package to automatically update your Raspberry Pi. Right now it is default to run update at 0400L but you can change that in the crontab. You still have to periodically run rpi-update manually since I don’t feel comfortable running kernel/firmware update automatically.
sudo apt-get install cron-apt -y
ls -hal /etc/cron-apt/config
ls -hal /etc/cron-apt/action.d/
echo ‘MAILON=“output”’ | sudo tee -a /etc/cron-apt/config
echo ‘DEBUG=“verbose”’ | sudo tee -a /etc/cron-apt/config
sudo touch /etc/cron-apt/action.d/5-security
echo ‘upgrade -y -o APT::Get::Show-Upgraded=true’ | sudo tee -a /etc/cron-apt/action.d/5-security
sudo touch /etc/cron-apt/config.d/5-security
echo ‘OPTIONS=“-o quiet=1 -o APT::Get::List-Cleanup=false -o Dir::Etc::SourceList=/etc/apt/sources.list.d/security.list -o Dir::Etc::SourceParts="/dev/null"”’ | sudo tee -a /etc/cron-apt/config.d/5-security
sudo chmod -R 755 /var/log/cron-apt
sudo cat /var/log/cron-apt/log
You will have to wait for next cycle to run before you see the log file or you can force run cron-apt in download (-d) mode to manually test it.
/Tailwinds ![]()
