Raspberry Pi 2 problem
Hi to all
I have two Raspberry Pi 2s that feed data, site two only feeds to FlightAware and I have no problem with it.
Site 1 feeds to four sites, but from time to time drops the connection to all the sites.
Even though the connection is down, I can connect to the Pi with VNC but not with the web interface.
I have changed the power supply to a genuine Pi one, also changed the wifi dongle but the problem persists!
Advice would be welcome
If it’s a wifi connection, please look here
==> http://weworkweplay.com/play/rebooting-the-raspberry-pi-when-it-loses-wireless-connection-wifi/
If you can connect using VNC, that means WiFi is working.
If you fail to debug, and it is NOT a hardware issue, then ultimate solution is re-imaging your microSD card. Painful to think of, not so difficult to do.
EDIT:
If you can connect on VPN, most likely you can SSH also.
  1. SSH and test you Dongle.
    #First install test tool package
    sudo apt-get update
    sudo apt-get install rtl-sdr
    # Stop dump1090 by one of the following command
    #depending on which version you have installed
    sudo systemctl stop dump1090-mutability
    #Now run the test
    rtl_test -t
   #If the Dongle is healthy, you will see following output
    Found 1 device(s):
      0:  Realtek, RTL2832U, SN: 00001000
    Sampling at 2048000 S/s.
    #Now reboot to restore system
    sudo reboot
  1. If the above test fails, unplug, then replug the Dongle, then reboot the Pi
