I am having issues with a new R-Pi 3 running the new Jessie 2.15 image. It came up OK on Ethernet, and I let it sit there for a couple of days to get a baseline feel for air traffic. I then enabled WiFi by editing the wpa_supplicant file, and got an IP address for wlan0 – all good so far. After less than a day, I realize it is offline and producing no data, so I have re-connected it to Ethernet.
Now I have two questions: [1] how do I set i up to reconnect if it loses WIFI? I’ve seen a post directing a user to here [flightaware.com/adsb/piaware/build/optional#wifi], but see no instructions on how do set up WIFI reconnect. Maybe the page has been changed recently… Any suggestions on how to do this?
[2] While plugged into the Ethernet, I am now getting two IP addresses. I can see the same aircraft plotting on both pages locally… I would prefer to have the WIFI turn on only if eht0 is not connected – is there a way to do that?
FWIW, this does not appear to be a network issue, as other computers are working fine, including my other Piaware server [R-Pi2, WiFi only], which has sat there delivering data consistently through all this.
If it doesn’t, can you mail me your syslog while it is in the broken state.
The Raspbian default is actually to do as you describe, but it makes it somewhat confusing when transitioning from wired to wireless so the piaware image disables it.
You can restore it by creating a symlink from /etc/ifplugd/action.d/action_wpa to /etc/wpa_supplicant/action_wpa.sh
Oh, sorry, I am guilty of skimming your post and not reading it properly. My instructions (including the “it should reconnect automatically”) are for the PiAware 3.0.4 image, not the older 2.1-5 image. If you’re doing wifi on 2.1-5 then yes you will have to mess around with the wifi settings yourself and probably arrange for it to reconnect. If you’re not particularly attached to the old image, try the new image?
Thanks. I looked at the link, and followed the instructions for editing the .txt file.
While the machine did come up on the network, the other machine went down right at that point. I will spend some time today sorting that out. Hopefully it was just a coincidence. It’s also possible I made a mistake, as I did have ssl sessions going for both machines, but I’d be surprised.
Is it safe to assume this approach will also work for the older versions of the software, running on older R-Pi hardware?
The PiAware 3 image will run fine on older hardware. You may be short on CPU on a B or B+, but that’s true regardless…
The wifi setup instructions I linked are for PiAware 3 only, not for older software versions.
