First I wanted to thank everyone for their help on my last issue.
Quick summary of what happened was a suspected power spike caused the smoke to escape my Odroid N2+ and damaged my ProStick Plus, but they functioned well enough to “work” but only barely… I recently got the recommended RPi equipment, and am now having a separate set of issues (mostly with FlightAware Feed being in an error state on the PiAware main load screen).
I am now running the following hardware:
*Raspberry PI 4 Model B w/ 1GB RAM
*Blue FlightAware Pro Stick for 1090 Rx
*Orange FlightAware Stick for 978 Rx
*1090/978 Nooelec antennas (have a 1/4 wavelength ground plane antenna for 1090 installed, but can’t easily remove for testing).
On the Welcome page of the PiAware 8.2 GUI, the anomalies are as follows:
*PiAware feeder consistently states normal and that “PiAware 8.2 is running” - no issues here.
*1090 Receiver fluctuates between Normal, and warning “Connected to Mode S Receiver, but no recent data seen” - Is this an element of testing inside and not having a good view of the outside?
FlightAware feed: after about 10-15 minutes it usually goes between a normal state and error. When in error it regularly states in “Error Not connected to FlightAware”
Multilateration: Usually is either “warning: No clock synchronation” or Error Multilateration enabled, but client not running" - I am going to assume this is a result of the above communication failure.
Open to ideas! Leaning to something on my home firewall/network but not sure if that would cause the issues?
