I have a RPi 2 with Piaware 3.6.3 installed, FlightAware Pro Stick SDR, a good DIY antenna and LAN connection.
In my new site (92476), tree green light, but y have no positions report and this problems:
[2018-12-01 09:23 -03] dump1090 start appears to have been successful
[2018-12-01 09:23 -03] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2018-12-01 09:23 -03] no ADS-B data program seen listening on port 30005 for 10 seconds, next check in 60s
I restart my system a couple of times, but nothing…
Any suggestions?
I’m gonna ask you again which sd-card image are you using?
Piaware 3.6.3
Copy pasting the output would be helpful.
If you are using Putty marking it should be enough. Then use CTRL-V to paste it here.
I will try. I must connect the Pi2 with HDMI to the TV.
If you don’t use ssh/putty then copy paste can’t work of course
Also try another usb port for the dongle.
And another power supply if you can, that’s always good to try.
(including another cable from power supply to pi)
