I have piaware running on a raspberry pi 4 have not looked at it in some time.
and it seems like i am not getting any data.
the web us is working and running in port 8080
but it is showing
Total Aircraft: 0
With Positions: 0 UAT Message Rate: 0.0/sec
Position History: 0
I remember a process running dump1090 in the past i do not see that process running now.
Anyone have a idea on what to look for or where to look for a answer?
You have two options.
The more comfortable is to access the process using your profile on Flightradar. For this go to your profile, select the gear and in the upcoming box you have parts of the log.
In this window you can either restart your whole device or the processes themselves only.
The second option require that you access your device via SSH
once logged in you can control the status of piaware with the command sudo systemctl status piaware
In case it does not state “active”, you can restart the service with sudo systemctl restart piaware
The simplest way is to reboot the whole device and check if it is working again.
restarting piaware was the first thing i did.
“sudo /etc/init.d/piaware restart”
no change.
and then reboot.
No change.
when I do a status
i@piaware:~ $ sudo systemctl status piaware
â—Ź piaware.service - FlightAware ADS-B uploader
Active: active (running) since Sun 2021-09-19 23:48:01 EDT; 8h ago
Main PID: 565 (piaware)
Tasks: 2 (limit: 4915)
└─565 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
Sep 20 08:24:10 piaware sudo[30177]: pam_unix(sudo:session): session closed for user root
Sep 20 08:24:10 piaware piaware[565]: no ADS-B data program is serving on port 30005, not starting multilateration client yet
Sep 20 08:25:06 piaware sudo[30232]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Sep 20 08:25:06 piaware sudo[30232]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 20 08:25:06 piaware sudo[30232]: pam_unix(sudo:session): session closed for user root
Sep 20 08:25:06 piaware piaware[565]: no ADS-B data program seen listening on port 30005 for 250 seconds, next check in 60s
Sep 20 08:25:10 piaware sudo[30243]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Sep 20 08:25:10 piaware sudo[30243]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 20 08:25:10 piaware sudo[30243]: pam_unix(sudo:session): session closed for user root
Sep 20 08:25:10 piaware piaware[565]: no ADS-B data program is serving on port 30005, not starting multilateration client yet
what is “no ADS-B data program is serving on port 30005, not starting multilateration client yet” telling me?
Think i found the probem.
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 086: ID 214b:7250
Bus 001 Device 085: ID 214b:7250
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I have a [LDKCOK USB 2.0 Type A Male to A Female Active Repeater Extension Cable 60ft
This cable has been working fine for 4 months
now I am not seeing the dongle
when I plug the dongle right into the pi and not use the extention cord i get
Bus 001 Device 078: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Why was it working for 4 months and now stop working?
