I just stood up a new installation of PiAware and the range ring setting is missing, any ideas?
Feeder Type: PiAware (SD Card) 7.2
Hello John,
Usually this is the case when the location isn’t set yet. Once claimed you can set is from the statistics page.
Did you create a new feeder and did you claim it ? Or are replacing the card from an existing receiver ?
I did claim the new install, and got a new Feeder ID. My SD card in an existing feeder went bad and needed to be replaced. If I could get my older feeder ID back that would be ideal
You can alter the feeder id in the file located at /var/cache/piaware/feeder_id
The old feeder Id can be obtained from your statistics page if you select the old Site ID.
Edit the file in the command
sudo nano /var/cache/piaware/feeder_id and replace the feeder ID in that file.
Save the file and restart the piaware software.
Then it wil become active with your old ID
Awesome, thank you, I will give it a go
