I’ve read what appeared to be good threads on the topic, but they always seem to veer off topic.
Anyhoo, I have dump1090 running on the Rapsberry. Finally discerned that there were additional command line parameters to include. What I have gleaned is to run with this:
The screen starts showing a few planes nearby. OK, so ran /etc/init.d/piaware start and then tail -f /tmp/piaware.out and get this:
04/07/2015 21:44:38 lost connection to faup1090, reconnecting…
04/07/2015 21:44:38 no ADS-B data program is serving on port 30005, next check in 60s
04/07/2015 21:45:38 ADS-B data program ‘dump1090’ is listening on port 30005, so far so good
04/07/2015 21:45:38 i see nothing serving on port 10001, starting faup1090…
04/07/2015 21:45:38 started faup1090 (process ID 7559)
04/07/2015 21:45:41 connecting to faup1090 on port 10001…
04/07/2015 21:45:41 piaware is connected to faup1090 on port 10001
04/07/2015 21:52:43 0 msgs recv’d from dump1090 via faup1090 (0 in last 5m); 0 msgs sent to FlightAware
Going to break out Wireshark and nail down who is supposed to be listening on what port. I wish the logs were a little less cryptic.
root@rp2:~# /etc/init.d/piaware status
piaware is running
So it’s running in the background. So I tail /tmp/piaware.out and we have:
root@rp2:~# tail -f /tmp/piaware.out
04/08/2015 01:58:37 no ADS-B data program is serving on port 30005, next check in 60s
04/08/2015 01:59:37 no ADS-B data program is serving on port 30005, next check in 60s
04/08/2015 02:00:37 no ADS-B data program is serving on port 30005, next check in 60s
04/08/2015 02:01:42 ADS-B data program ‘dump1090’ is listening on port 30005, so far so good
04/08/2015 02:01:42 i see nothing serving on port 10001, starting faup1090…
04/08/2015 02:01:42 started faup1090 (process ID 2567)
04/08/2015 02:01:45 connecting to faup1090 on port 10001…
04/08/2015 02:01:45 piaware is connected to faup1090 on port 10001
04/08/2015 02:02:37 seconds since last message or startup (2710) less than threshold for action (3600), waiting…
04/08/2015 02:03:07 0 msgs recv’d from dump1090 via faup1090 (0 in last 5m); 0 msgs sent to FlightAware
It seems to be happy, but no messages are being transmitted and it does a lot of “waiting”.
Got it working by switching to a different dump1090. I had read that any of them would work, and so was using antirez’s. Switched to one that has a different header line (includes Sqwk, Sig) and it started working. Who knew?
Here’s a recent snapshot:
Hex Mode Sqwk Flight Alt Spd Hdg Lat Long Sig Msgs Ti-
ADC932 S 7157 21975 11 77 0
A6D9BF S 11775 36 158 0
A8B848 S 3123 26825 34 548 0
ADFE78 S RCH 140 23900 12 220 0
A1584A S 9125 8 610 1
AA1EE5 S 28000 5 202 7
A42EFC S 7135 DAL2578 28050 15 998 0
Ah, right, I missed that you were using --net-ro-port. Basically the problem is that faup1090 expects Beast-format output on port 30005. antirez’s original version can’t generate Beast-format output, it only generates the AVR format.
