Just built a piaware device and manually configured the login and password. After waiting for several hours and not being able to claim my device, I ran sudo piaware-status and received the following:
dump1090 is running.
faup1090 is running.
piaware is running.
dump1090 is listening for connections on port 30005.
faup1090 is connected to port 30005.
dump1090 is producing data on port 30005.
Additionally, I ran sudo piaware -debug:
pi@piaware ~ $ sudo piaware -debug
01/10/2016 18:21:28 ****************************************************
01/10/2016 18:21:28 piaware version 2.1-5 is running, process ID 6236
01/10/2016 18:21:28 your system info is: Linux piaware 4.1.13-v7+ #826 SMP PREEMPT Fri Nov 13 20:19:03 GMT 2015
armv7l GNU/Linux
01/10/2016 18:21:29 Connecting to FlightAware adept server at piaware.flightaware.com/1200
01/10/2016 18:21:29 ADS-B data program ‘dump1090’ is listening on port 30005, so far so good
01/10/2016 18:21:29 Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout
01/10/2016 18:21:29 Started faup1090 (pid 6248) to connect to dump1090
01/10/2016 18:21:29 Connection with adept server at piaware.flightaware.com/1200 established
01/10/2016 18:21:29 FlightAware server SSL certificate validated
01/10/2016 18:21:29 encrypted session established with FlightAware
01/10/2016 18:21:29 autoUpdate is not set in adept config, looking further…
01/10/2016 18:21:29 autoUpdate in /etc/piaware is enabled, allowing update
01/10/2016 18:21:29 manualUpdate is not set in adept config, looking further…
01/10/2016 18:21:29 manualUpdate in /etc/piaware is enabled, allowing update
01/10/2016 18:21:29 multilateration support enabled (use piaware-config to disable)
01/10/2016 18:21:30 logged in to FlightAware as user chris12381
01/10/2016 18:21:32 piaware received a message from dump1090!
01/10/2016 18:21:59 6 msgs recv’d from dump1090; 6 msgs sent to FlightAware
01/10/2016 18:22:02 piaware has successfully sent several msgs to FlightAware!
I can see aircraft on the local dump1090 map. So, based on the above output(s) piaware is communicating and sending data to flightaware successfully under my flightaware account.
However, when I try and claim the device, I’m told “Unfortunately, FlightAware hasn’t found a new, unclaimed PiAware connection yet from your IP (xxxxxxxxxxxxxxxxxxxxxxxxxx). Either your device has not yet connected (it takes a few minutes to start) or you are on a different IP address.”
Oddly, right below this message, flightaware says, "Linked PiAware Receivers (chris12381)
Great news! Your account is associated with the following PiAware receivers and you can view your statistics here:
b8:27:eb:2e:a1:f0: PiAware (SD Card) 2.1 added Wednesday, 6 January 2016 (XXX.XXX.XXX.XXX / 10.0.0.15)"
However, when I click the link for stats, I’m told “No Active FlightAware ADS-B Sites For This User (chris12381)”
Can anyone assist me with this?
Thanks,
Chris
