ppup1090 requires use of a binary-only object file with an unclear license that is tied to a particular build of dump1090. As such it is unsupportable.
If Bev were to document the data format that ppup1090 produces, I could implement that, but currently it is impossible to support. You should ask Bev about this.
To compile your ppup1090 file, you HAVE to dowload the Malcolm Robb fork of Dump1090, EVEN if you use something else for actual decoding. Just download it into a separate diectory, compile your ppup1090, and let ppup connect to the default port 30005 to get it’s data.
I have done this and use Dump1090-mutability for decoding, but had to use the -Robb fork for ppup compilation.
