@abcd567 I installed 32-bit Raspbian (not 64) as I wasnât sure if all the FA/FR24 stuff was compatible with a 64bit OS.
I recreated my install âone step at a timeâ and checked as it went.
I loaded the OS (32-bit Bullseye) and confirmed that VNC is working,
I loaded PiAware, confirmed that itâs working (sending data to FA) and that VNC is working.
My next step was to activate FR24 per (Re-imaging Made Easy) Section 3.2
I created the fr24feed.ini file and populated it with the previous data, and then executed:
sudo bash -c "$(wget -O - https://repo-feed.flightradar24.com/install_fr24_rpi.sh)"
and what I get back finishes likeâŚ
Hit:1 http://flightaware.com/adsb/piaware/files/packages bullseye InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
Reading package lists... Done
Building dependency tree... Done
dirmngr is already the newest version (2.2.27-2+deb11u2).
The following package was automatically installed and is no longer required:
libfuse2
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
Executing: /tmp/apt-key-gpghome.WqM7tDuxwc/gpg.1.sh --recv-key --keyserver keyserver.ubuntu.com C969F07840C430F5
gpg: keyserver receive failed: Server indicated a failure
Executing: /tmp/apt-key-gpghome.XADxvxJvr5/gpg.1.sh --recv-key --keyserver pool.sks-keyservers.net C969F07840C430F5
Executing: /tmp/apt-key-gpghome.17F6gLHavv/gpg.1.sh --recv-key --keyserver pgp.mit.edu C969F07840C430F5
pi@PiPlane:~ $
multiple âfailuresâ and then it stops.
The steps on the above-linked webpage, state that the command should keep running and start the configuration process. Then I should end that process via (Ctrl+C), and start up the fr24feed via:
sudo systemctl restart fr24feed
However, I never get a chance to Ctrl+C, it just dies. If I try to start the process, I get back:
pi@PiPlane:~ $ sudo systemctl restart fr24feed
Failed to restart fr24feed.service: Unit fr24feed.service not found.
At this point VNC is still working.
Then I did âoption 2â from the Fr24 manual:
wget https://repo-feed.flightradar24.com/rpi_binaries/fr24feed_1.0.23-8_armhf.deb
sudo dpkg -i fr24feed_1.0.23-8_armhf.deb
and it seemed to work - including asking if I wanted to keep the existing config file.
I rebooted, and now it seems to be working - both FA, FR24, and VNC (?)
So - VNC is working now - when (I think) it wasnât working on the identical effort yesterday.
I am not going to try a third time, though, Iâm taking âsuccessâ and running with it.
But as to getting FR24 functional, I again confirmed that the âOption 1â approach doesnât work for me. Iâm not sure if thatâs due to the 32/64 bit question, maybe a Buster/Bullseye issue, or something else. The fact others havenât complained makes me wonder whatâs wrong with my setup, but Iâve made copious notes to myself so that if/when I have to do this again, Iâll have a recipe for getting to the end.
Again, I greatly appreciate all the time and attention youâve provided here (and in other threads in the various forums FA and FR24 that Iâve been reading).
Regards,
âMark
