I have gotten multiple conflicting opinions/reports on this topic, so I’ll throw it out to the board. Is it safe/wise/risky/etc to run a 1993 Piper Saratoga’s 300hp Lycoming lean of peak? I only have one CHT gauge and an EGT gauge.
Although I have zero experience with a Saratoga, the common wisdom I have usually heard on LOP operations is to only do so if you have a an engine anaylzer that shows CHTs for all cylinders. That way you don’t chance burning out one cylinder that is running a little leaner than the one you have a CHT for.
The general consensus reached on another forum was not to run LOP on turbocharged engines, over 75% power and be fully equipped i.e. full CHT and EGT gauges with sensors on each cylinder. That was not engine specific, just in general. Some of the higher time pilots said they would not run lean over 65% power and a few brought up specific engines they would not do it on, though I don’t remember which ones. The thread was interesting to read but since my present ride does not have a mixture control I admit I did not pay more attention to it.
At AMF (Ameriflight) they are able to extend the TBO on the TIO-520 by 750 hours because they train all their pilots to lean 150 degrees rich of peak and to stage cool 2" of MP every 2min.
that extension comes from the manufacturer. I’m still a baby when it come to experience in the High Performance piston airplanes- I only have about 3,500 hours in them but I know that you don’t run hot.
Stage cooling for sure has a lot to do with longevity. I’m not so sure that leaning 150 ROP is that much better than 50 ROP though. On a high compression engine, or TC’d like the Navajo I would never go LOP.
I would be leary of pushing temps with only one CHT reading. My Saratoga has CHT sensors on all cylinders. The temp varies from 400 (mfgr recommended max for long term operation) on cyl 2 to a low of 324 on three other cylinders. A single temp sensor on the lowest temp cylinder could result in a possible 470+ temp on the hottest cylinder. This condition is less than the 500 degree short term max temp, but well in excess of the mfgr desired long term max.
Regarding lean of peak vs rich of peak - my mechanic says that lean of peak operations improves his business sufficiently that he too can afford to fly! Many writings have been provided on this website regarding LOP vs ROP, check them out, but look to the manufacturer for sure-fire advice.
I found that if I ran extremely rich, such as when I first got the plane, I would get a lot of plug fouling.
My instrument instructor then helped me with the math to show that running a reasonable ROP rather than extremely rich saved enough money to pay for an engine overhaul. Briefly, let’s say you burn 3 gal/hr more than necessary to run overrich to keep the engine cool. At roughly $4.50 to $5./gallon over a 2,000 hour engine life yeilded a cost of $27 to $30K which is about what the rebuild cost is for the TIO 540. His point was don’t burn the extra avgas when you save nothing on an engine rebuild. In short, if the manufacturer gives you a fuel burn rate of 16 gpm and you burn at 19 gpm under similar load conditions, you are wasting money.
Here are the assumptions; Lycombing recoomeds TBO at 2,000 hours, Continental is different at 1,700 hours. That the rebuild cost is a standard rebuild and doesn’t include excessive damage or turbo rebuild cost. That fuel stays at $4.5 to $5/gal over the 2,000 hours, that the 16 gpm provides you with the mfgr recommended chts and tits, etc.
GAMI and JPI. I’ve been running the IO-520 lean of peak as long as I’ve owned it. Did the flight test program with GAMI staff, which previous owner never bothered to complete. Best time ever spent as “GAMI spread” now near zero. GAMI staffers very helpful.
You guys that think rich is saving engine parts just haven’t seen enough data.
Don’t try this at high power, low altitude or without the right 6 cyl. data, but if you want less wear, lower fuel bills and are willing to learn, go to GAMI’s website and read about BMEP and how the airliners of the 1950’s did it before the jet age. BMEP was “state of the art” at the time. May I be so bold as to suggest your piston engine is 1950 technology, so use the concepts that were developed with it.
