The piaware install fails with:
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
The following information may help to resolve the situation:
piaware:armhf : Depends: tcllib:armhf but it is not installable
E: Unable to correct problems, you have held broken packages.
ok. I already have 1090-mutubality, frfeed, planefinder, and radarbox set up and working. Would you suggest purging the 1090-mutability and replacing with 1090-fa as first step? I’m thinking that adding th 1090-fa should restart these 3 feeders, correct/
