Hi all,
I’m relatively new to the ADS-B space, so please bear with me!
I bought the FA Pro Stick Plus and a 1090mhz antenna from ModMyPi, which I’ve got setup on a Debian 9 system running dump1090-mutability. I’d love to feed FlightAware, but the only instructions I can readily find are about running PiAware on a Raspberry Pi.
What’s the best way to feed FA using my current setup?
I have looked at that page, but the apt repository that it adds doesn’t contain any packages for the amd64 architecture - I presume they’ve been pre-built for the rPI. That means I still can’t actually install PiAware.
Thank you for the link though!
How good is your Linux command line knowledge?
You will need to be basically comfortable with that first.
I built a package on an Intel Atom thin client by following this thread (and adapting the file names to suit - check what is created with the ‘ls’ (LS) command).
post177419.html#p177419
You will get some files ending with something like dump1090-mutability_1.15~dev_x86.deb instead of e.g. dump1090-mutability_1.15~dev_armhf.deb
I first made a vanilla install of Debian and added the user …
You can build it from scratch
sudo apt-get update
sudo apt-get install build-essential debhelper tcl8.6-dev autoconf python3-dev python3-venv dh-systemd libz-dev
git clone GitHub - flightaware/piaware_builder: Debian package builder for piaware
cd piaware_builder
chmod +x sensible-build.sh
sh sensible-build.sh jessie
cd package-jessie
dpkg-buildpackage -b
Then install the package it creates
something like
sudo dpkg -i (package name/location)
The manual method posted by @jonhawkes2030 is good and works OK.
If you want easier automated method, use J Prochazka’s scripts by giving commands below:
sudo apt-get update
sudo apt-get install git
cd ~/
git clone https://github.com/jprochazka/adsb-receiver.git
cd ~/adsb-receiver
chmod +x install.sh
./install.sh
Thanks @jonhawkes2030 - I did indeed get it working as per your instructions, but in my excitement forgot to update the post!
Thank you all for your help
I have only problems with the script from J Prochazka, especially at the end with the web based creation of mysql or sqlite. The repository hasn’t been uodated for a long time.
Any other source for debian install script. ?
Erik
Install dump1090-mutability ver 1.15~dev from Source Code
(1) Install tools & dependencies
sudo apt-get update
sudo apt-get install -y git build-essential debhelper rtl-sdr
sudo apt-get install -y librtlsdr-dev libusb-1.0-0-dev pkg-config
sudo apt-get install -y fakeroot curl cron lighttpd
(2) Clone source code and build package
cd ~/
sudo git clone https://github.com/mutability/dump1090.git
cd ~/dump1090
sudo dpkg-buildpackage -b
(3) Install and configure dump1090-mutability
cd ../
sudo dpkg -i dump1090-mutability_1.15~dev_*.deb
sudo lighty-enable-mod dump1090
sudo /etc/init.d/lighttpd force-reload
(4) WORKAROUND FOR STRETCH (Ajax call Failed) …"
sudo wget -O /etc/udev/rules.d/rtl-sdr.rules "https://raw.githubusercontent.com/osmocom/rtl-sdr/master/rtl-sdr.rules"
sudo reboot
pa0esh
July 6, 2019, 10:54pm
11
Thanks, building right now. All went without errors, but when i dial-up the page dump1090, the bottom status that there is no data
Checking the status
root@adsb:/home/erik# systemctl status dump1090-mutability
● dump1090-mutability.service - LSB: dump1090 daemon (mutability variant)
Loaded: loaded (/etc/init.d/dump1090-mutability; generated; vendor preset: enabled)
Active: active (exited) since Sun 2019-07-07 01:14:56 CEST; 10s ago
Docs: man:systemd-sysv-generator(8)
Process: 8772 ExecStop=/etc/init.d/dump1090-mutability stop (code=exited, status=0/SUCCESS)
Process: 8794 ExecStart=/etc/init.d/dump1090-mutability start (code=exited, status=0/SUCCESS)
Jul 07 01:14:55 adsb systemd[1]: Starting LSB: dump1090 daemon (mutability variant)…
Jul 07 01:14:56 adsb systemd[1]: Started LSB: dump1090 daemon (mutability variant).
There are no json files in /run/dump1090-mutability
Need to investigate more…
Oops… Forgot to post this step:
(Will edit post and add it now)
STRETCH WORKAROUND (Ajax call Fail) ...."
sudo reboot
pa0esh
July 7, 2019, 5:53am
13
Thanks for the update, all is working now…
