OK, I’m not a computer guy. All of a sudden PiAware on my local computer stopped receiving data and I get this ‘error’ message. But SkyAware is receiving data and displaying what PiAware would normally be displaying. Any help would be greatly appreciated.
If the image is not coming through, it’s a spinning gear with a line below it where a blue bar moves back and forth on a white line.
I tried to upgrade my Raspberry Pi to version 7 and that didn’t help.
For those WAY savier than I, here’s the log:
This seems to be a consistent error message throughout the log below:
[2021-12-27 14:49 MST] mlat-client(8611): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 14:57 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::197:10668:3781777805
[2021-12-27 14:57 MST] got EOF from multilateration client
[2021-12-27 14:57 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 14:57 MST] mlat-client(8952): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 14:57 MST] faup1090(560): handleFaupCommand(): Adjusting message rate to FlightAware by 1.00x
[2021-12-27 14:57 MST] adept server faup request received: faup_adjust_upload_rate
[2021-12-27 14:57 MST] faup1090(560): handleFaupCommand(): Adjusting message rate to FlightAware by 3.00x
[2021-12-27 14:58 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 14:58 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::197:10668:3781777805
[2021-12-27 14:58 MST] got EOF from multilateration client
[2021-12-27 14:58 MST] mlat-client(8998): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 14:59 MST] got EOF from multilateration client
[2021-12-27 14:59 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::197:10668:3781777805
[2021-12-27 14:59 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 14:59 MST] mlat-client(9043): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:00 MST] adept server faup request received: faup_adjust_upload_rate
[2021-12-27 15:00 MST] faup1090(560): handleFaupCommand(): Adjusting message rate to FlightAware by 1.00x
[2021-12-27 15:00 MST] mlat-client(9084): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:00 MST] got EOF from multilateration client
[2021-12-27 15:00 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:00 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::197:10668:3781777805
[2021-12-27 15:00 MST] 151007 msgs recv’d from dump1090-fa (6733 in last 5m); 150363 msgs sent to FlightAware
[2021-12-27 15:01 MST] mlat-client(9127): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:01 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::197:10668:3781777805
[2021-12-27 15:01 MST] got EOF from multilateration client
[2021-12-27 15:01 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:02 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:02 MST] got EOF from multilateration client
[2021-12-27 15:02 MST] mlat-client(9174): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:02 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::197:10668:3781777805
[2021-12-27 15:02 MST] adept server faup request received: faup_adjust_upload_rate
[2021-12-27 15:02 MST] faup1090(560): handleFaupCommand(): Adjusting message rate to FlightAware by 3.00x
[2021-12-27 15:04 MST] multilateration data requested
[2021-12-27 15:04 MST] logged in to FlightAware as user JerrytheK
[2021-12-27 15:04 MST] adept reported location: 39.63940, -104.91519, 5651ft AMSL
[2021-12-27 15:04 MST] my feeder ID is 818b37d9-3f20-4c0a-a8f4-f2239887a2f6
[2021-12-27 15:04 MST] mlat-client(708): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:04 MST] 581 msgs recv’d from dump1090-fa; 209 msgs sent to FlightAware
[2021-12-27 15:05 MST] multilateration data requested
[2021-12-27 15:05 MST] got EOF from multilateration client
[2021-12-27 15:05 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:05 MST] 1592 msgs recv’d from dump1090-fa (1011 in last 48m); 991 msgs sent to FlightAware
[2021-12-27 15:06 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:06 MST] got EOF from multilateration client
[2021-12-27 15:06 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:06 MST] mlat-client(1370): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:07 MST] mlat-client(1443): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:07 MST] got EOF from multilateration client
[2021-12-27 15:07 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:07 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:08 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:08 MST] got EOF from multilateration client
[2021-12-27 15:08 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:08 MST] mlat-client(1512): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:09 MST] got EOF from multilateration client
[2021-12-27 15:09 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:09 MST] mlat-client(1566): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:09 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:10 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:10 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:10 MST] got EOF from multilateration client
[2021-12-27 15:10 MST] mlat-client(1626): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:10 MST] 5048 msgs recv’d from dump1090-fa (3456 in last 5m); 4447 msgs sent to FlightAware
[2021-12-27 15:11 MST] got EOF from multilateration client
[2021-12-27 15:11 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:11 MST] mlat-client(1692): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:11 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:12 MST] mlat-client(1749): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:12 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:12 MST] got EOF from multilateration client
[2021-12-27 15:12 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:13 MST] got EOF from multilateration client
[2021-12-27 15:13 MST] mlat-client(1802): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:13 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:13 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:14 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:14 MST] mlat-client(1867): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:14 MST] got EOF from multilateration client
[2021-12-27 15:14 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:15 MST] mlat-client(1923): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:15 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:15 MST] got EOF from multilateration client
[2021-12-27 15:15 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:15 MST] 8582 msgs recv’d from dump1090-fa (3534 in last 5m); 7981 msgs sent to FlightAware
[2021-12-27 15:16 MST] got EOF from multilateration client
[2021-12-27 15:16 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:16 MST] mlat-client(1973): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:16 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:17 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:17 MST] got EOF from multilateration client
[2021-12-27 15:17 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:17 MST] mlat-client(2044): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:18 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:18 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:18 MST] got EOF from multilateration client
[2021-12-27 15:18 MST] mlat-client(2097): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:19 MST] got EOF from multilateration client
[2021-12-27 15:19 MST] mlat-client(2145): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:19 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:19 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:20 MST] mlat-client(2209): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:20 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:20 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:20 MST] got EOF from multilateration client
[2021-12-27 15:20 MST] 11743 msgs recv’d from dump1090-fa (3161 in last 5m); 11142 msgs sent to FlightAware
[2021-12-27 15:21 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:21 MST] mlat-client(2263): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:21 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:21 MST] got EOF from multilateration client
[2021-12-27 15:22 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:22 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:22 MST] mlat-client(2317): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:22 MST] got EOF from multilateration client
[2021-12-27 15:23 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:23 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:23 MST] mlat-client(2375): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:23 MST] got EOF from multilateration client
[2021-12-27 15:24 MST] *** running command ‘/usr/lib/piaware/helpers/run-apt-get update’ and logging output
[2021-12-27 15:24 MST] performing manual update, action: piaware
[2021-12-27 15:24 MST] manual update (user-initiated via their flightaware control page) requested by adept server
[2021-12-27 15:24 MST] mlat-client(2431): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:24 MST] got EOF from multilateration client
[2021-12-27 15:24 MST] run-apt-get(2417): Get:3 http://flightaware.com/mirror/raspberrypi/debian stretch InRelease [25.3 kB]
[2021-12-27 15:24 MST] run-apt-get(2417): Get:2 http://flightaware.com/adsb/piaware/files/packages stretch InRelease [1,859 B]
[2021-12-27 15:24 MST] run-apt-get(2417): Get:4 http://flightaware.com/mirror/raspbian/raspbian stretch/main armhf Packages [11.7 MB]
[2021-12-27 15:24 MST] run-apt-get(2417): Get:6 http://flightaware.com/mirror/raspberrypi/debian stretch/main armhf Packages [192 kB]
[2021-12-27 15:24 MST] run-apt-get(2417): Get:5 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf Packages [7,070 B]
[2021-12-27 15:24 MST] skipping action piaware
[2021-12-27 15:24 MST] run-apt-get(2588): E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
[2021-12-27 15:24 MST] run-apt-get(2588): E: Problem with MergeList /var/lib/apt/lists/flightaware.com_mirror_raspbian_raspbian_dists_stretch_main_binary-armhf_Packages
[2021-12-27 15:24 MST] run-apt-get(2588): E: Encountered a section with no Package: header
[2021-12-27 15:24 MST] run-apt-get(2588): E: The package lists or status file could not be parsed or opened.
[2021-12-27 15:24 MST] update request complete
[2021-12-27 15:24 MST] child process 2588 exited with status EXIT 100
[2021-12-27 15:24 MST] run-apt-get(2588): Reading package lists…
[2021-12-27 15:24 MST] run-apt-get(2588): E: Unable to lock directory /var/lib/apt/lists/
[2021-12-27 15:24 MST] run-apt-get(2417): Fetched 11.9 MB in 16s (708 kB/s)
[2021-12-27 15:24 MST] *** running command ‘/usr/lib/piaware/helpers/run-apt-get upgrade-package piaware-release’ and logging output
[2021-12-27 15:24 MST] run-apt-get(2417): Reading package lists…
[2021-12-27 15:25 MST] run-apt-get(2628): Reading package lists…
[2021-12-27 15:25 MST] run-apt-get(2628): Building dependency tree…
[2021-12-27 15:25 MST] run-apt-get(2628): Reading state information…
[2021-12-27 15:25 MST] run-apt-get(2628): skyview978
[2021-12-27 15:25 MST] run-apt-get(2628): Use ‘sudo apt autoremove’ to remove it.
[2021-12-27 15:25 MST] run-apt-get(2628): The following packages will be upgraded:
[2021-12-27 15:25 MST] run-apt-get(2628): Need to get 11.1 MB of archives.
[2021-12-27 15:25 MST] run-apt-get(2628): Get:3 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf piaware armhf 6.1~bpo9+1 [2,884 kB]
[2021-12-27 15:25 MST] run-apt-get(2628): beast-splitter dump1090-fa dump978-fa piaware piaware-release
[2021-12-27 15:25 MST] run-apt-get(2628): The following package was automatically installed and is no longer required:
[2021-12-27 15:25 MST] run-apt-get(2628): 9 upgraded, 0 newly installed, 0 to remove and 158 not upgraded.
[2021-12-27 15:25 MST] run-apt-get(2628): Get:2 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf piaware-repository all 6.1~bpo9+1 [6,172 B]
[2021-12-27 15:25 MST] run-apt-get(2628): The following additional packages will be installed:
[2021-12-27 15:25 MST] run-apt-get(2628): Get:1 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf piaware-release all 6.1~bpo9+1 [130 kB]
[2021-12-27 15:25 MST] run-apt-get(2628): piaware-support piaware-web skyaware978
[2021-12-27 15:25 MST] run-apt-get(2628): piaware-repository piaware-support piaware-web skyaware978
[2021-12-27 15:25 MST] run-apt-get(2628): beast-splitter dump1090-fa dump978-fa piaware piaware-repository
[2021-12-27 15:25 MST] run-apt-get(2628): After this operation, 0 B of additional disk space will be used.
[2021-12-27 15:25 MST] run-apt-get(2628): Get:4 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf piaware-support all 6.1~bpo9+1 [20.7 kB]
[2021-12-27 15:25 MST] run-apt-get(2628): Get:5 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf dump1090-fa armhf 6.1~bpo9+1 [5,263 kB]
[2021-12-27 15:25 MST] run-apt-get(2628): Get:6 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf dump978-fa armhf 6.1~bpo9+1 [143 kB]
[2021-12-27 15:25 MST] run-apt-get(2628): Get:7 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf skyaware978 armhf 6.1~bpo9+1 [2,489 kB]
[2021-12-27 15:25 MST] run-apt-get(2628): Get:9 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf beast-splitter armhf 6.1~bpo9+1 [101 kB]
[2021-12-27 15:25 MST] run-apt-get(2628): Get:8 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf piaware-web all 6.1~bpo9+1 [82.9 kB]
[2021-12-27 15:25 MST] mlat-client(2680): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 15:25 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::201:12818:2497204843
[2021-12-27 15:25 MST] got EOF from multilateration client
[2021-12-27 15:25 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 15:25 MST] run-apt-get(2628): apt-listchanges: Reading changelogs…
[2021-12-27 15:25 MST] run-apt-get(2628): Fetched 11.1 MB in 3s (3,648 kB/s)
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 25%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 55%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 10%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 35%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 70%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 30%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 65%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 15%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 60%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 95%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 40%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 50%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 5%
[2021-12-27 15:25 MST] run-apt-get(2628): Preparing to unpack …/0-piaware-release_6.1~bpo9+1_all.deb …
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 20%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 45%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 90%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 40381 files and directories currently installed.)
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 85%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 80%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 100%
[2021-12-27 15:25 MST] run-apt-get(2628): (Reading database … 75%
[2021-12-27 15:25 MST] run-apt-get(2628): Unpacking piaware-release (6.1~bpo9+1) over (6.0~bpo9+1) …
[2021-12-27 15:25 MST] run-apt-get(2628): Preparing to unpack …/1-piaware-repository_6.1~bpo9+1_all.deb …
[2021-12-27 15:25 MST] run-apt-get(2628): Unpacking piaware-repository (6.1~bpo9+1) over (6.0~bpo9+1) …
[2021-12-27 15:25 MST] run-apt-get(2628): Preparing to unpack …/2-piaware_6.1~bpo9+1_armhf.deb …
[2021-12-27 15:25 MST] piaware (process 416) is shutting down because it received a shutdown signal (SIGTERM) from the system…
[2021-12-27 15:25 MST] piaware (process 416) is exiting…
[2021-12-27 15:25 MST] multilateration data no longer required, disabling mlat client
[2021-12-27 15:25 MST] faup1090 exited with SIG SIGHUP
[2021-12-27 15:52 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 206.253.84.194:7797:1108720516
[2021-12-27 15:52 MST] my feeder ID is 818b37d9-3f20-4c0a-a8f4-f2239887a2f6
[2021-12-27 15:52 MST] site statistics URL: JerrytheK ADS-B Feeder Statistics - FlightAware
[2021-12-27 16:03 MST] my feeder ID is 818b37d9-3f20-4c0a-a8f4-f2239887a2f6
[2021-12-27 16:03 MST] multilateration data requested
[2021-12-27 16:03 MST] adept reported location: 39.63940, -104.91519, 5651ft AMSL
[2021-12-27 16:03 MST] got EOF from multilateration client
[2021-12-27 16:03 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 16:04 MST] 509 msgs recv’d from dump1090-fa; 217 msgs sent to FlightAware
[2021-12-27 16:04 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 206.253.80.196:15739:3335813061
[2021-12-27 16:04 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 16:04 MST] got EOF from multilateration client
[2021-12-27 16:04 MST] mlat-client(921): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 16:05 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 16:05 MST] multilateration data requested
[2021-12-27 16:05 MST] 1410 msgs recv’d from dump1090-fa (901 in last 48m); 924 msgs sent to FlightAware
[2021-12-27 16:06 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::196:15758:1979260168
[2021-12-27 16:06 MST] got EOF from multilateration client
[2021-12-27 16:06 MST] mlat-client(1278): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 16:06 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 16:06 MST] adept server faup request received: faup_adjust_upload_rate
[2021-12-27 16:06 MST] faup1090(557): handleFaupCommand(): Adjusting message rate to FlightAware by 3.00x
[2021-12-27 16:07 MST] mlat-client(1339): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 16:07 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 16:07 MST] got EOF from multilateration client
[2021-12-27 16:07 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::196:15758:1979260168
[2021-12-27 16:08 MST] mlat-client(1400): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 16:08 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 16:08 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::196:15758:1979260168
[2021-12-27 16:08 MST] got EOF from multilateration client
[2021-12-27 16:09 MST] mlat-client(1466): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 16:09 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 16:09 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::196:15758:1979260168
[2021-12-27 16:09 MST] got EOF from multilateration client
[2021-12-27 16:10 MST] mlat-client(1530): /usr/lib/piaware/helpers/fa-mlat-client: error while loading shared libraries: lmbe?pat.so.1: cannot open shared object file: No such file or directory
[2021-12-27 16:10 MST] fa-mlat-client exited with EXIT 127
[2021-12-27 16:10 MST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 2620:13d:c000:11::196:15758:1979260168
[2021-12-27 16:10 MST] got EOF from multilateration client
Thanks in advance.
