Piaware connection time out (no syn,ack reply from server)
Hi all, i’ve just finished the installation of my ADS-B tracking setup. I am using dump1090-fa as the ADS-B decoder with a Radarbox dongle+antenna and a Sysmocom cavity filter and I am currently in the process of setting up the feeding software.
I have been trying to setup Piaware to feed to Flightaware’s server but I haven’t been able to acquire a connection to the servers. The logs say as follows:
Dec 23 11:45:32 adsb piaware[12537]: ****************************************************
Dec 23 11:45:32 adsb piaware[12537]: piaware version 4.0 is running, process ID 12537
Dec 23 11:45:32 adsb piaware[12537]: your system info is: Linux adsb.localdomain 5.9.14-sunxi #20.11.3 SMP Fri Dec 11 20:31:12 CET 2020 armv7l GNU/Linux
Dec 23 11:45:33 adsb piaware[12537]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
Dec 23 11:45:36 adsb piaware[12537]: ADS-B data program 'dump1090-fa' is listening on port 30005, so far so good
Dec 23 11:45:36 adsb piaware[12537]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout
Dec 23 11:45:36 adsb piaware[12537]: Started faup1090 (pid 12554) to connect to dump1090-fa
Dec 23 11:45:36 adsb piaware[12537]: UAT support disabled by local configuration setting: uat-receiver-type
Dec 23 11:45:36 adsb piaware[12537]: piaware received a message from dump1090-fa!
Dec 23 11:45:49 adsb piaware[12537]: Connection attempt with adept server at piaware.flightaware.com/1200 timed out
Dec 23 11:45:49 adsb piaware[12537]: reconnecting in 6 seconds...
Dec 23 11:45:55 adsb piaware[12537]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
Dec 23 11:46:06 adsb piaware[12537]: 52 msgs recv'd from dump1090-fa; 0 msgs sent to FlightAware
Dec 23 11:46:10 adsb piaware[12537]: Connection attempt with adept server at piaware.flightaware.com/1200 timed out
Dec 23 11:46:10 adsb piaware[12537]: reconnecting in 4 seconds...
Dec 23 11:46:14 adsb piaware[12537]: Connecting to FlightAware adept server at 70.42.6.198/1200
Dec 23 11:46:29 adsb piaware[12537]: Connection attempt with adept server at 70.42.6.198/1200 timed out
Dec 23 11:46:29 adsb piaware[12537]: reconnecting in 4 seconds...
Dec 23 11:46:33 adsb piaware[12537]: Connecting to FlightAware adept server at 70.42.6.225/1200
Dec 23 11:46:48 adsb piaware[12537]: Connection attempt with adept server at 70.42.6.225/1200 timed out
Dec 23 11:46:48 adsb piaware[12537]: reconnecting in 6 seconds...
Dec 23 11:46:54 adsb piaware[12537]: Connecting to FlightAware adept server at 70.42.6.156/1200
Dec 23 11:47:09 adsb piaware[12537]: Connection attempt with adept server at 70.42.6.156/1200 timed out
Dec 23 11:47:09 adsb piaware[12537]: reconnecting in 5 seconds...
Dec 23 11:47:14 adsb piaware[12537]: Connecting to FlightAware adept server at 70.42.6.232/1200
Dec 23 11:47:29 adsb piaware[12537]: Connection attempt with adept server at 70.42.6.232/1200 timed out
Dec 23 11:47:29 adsb piaware[12537]: reconnecting in 5 seconds...
Dec 23 11:47:34 adsb piaware[12537]: Connecting to FlightAware adept server at 70.42.6.228/1200
Dec 23 11:47:49 adsb piaware[12537]: Connection attempt with adept server at 70.42.6.228/1200 timed out
Dec 23 11:47:49 adsb piaware[12537]: reconnecting in 5 seconds...
and so on. (EDIT: I installed Piaware on Armbian with Orange Pi Zero LTS as the SBC. I tried both prebuilt package and self-compiled package; both has the same issue)
I’ve tried basic troubleshooting such as ping (which is nominal). I checked my firewall which is allowing new outbound connections by default. When I checked the NAT table, it seems that my device didn’t get the reply to the SYN request and timed out.
Would you mind helping me troubleshoot the setup? As for some info, I live in Indonesia (in case the firewall bans all Indonesian IPs, which seems to be the case with some US-based services) My current dynamic public IP subnet is 139.192.87.0/24 and I can PM the IP address if it is strictly required.
Cheers,
Hugo
