Good afternoon,
I’m new to PiAware - But I bought the kit and have installed PiAware / FlightAware using the image file and web instructions. Connected it to WiFi and it logged it and is connected. But, for whatever reason, the dump1090 doesn’t seem to be connected. I’ve tried to restart / update / etc. I’ve checked all the connections, several times.
Any ideas???
Here is the log since I started the device for the first time…
Thanks!!!
2022-05-07 11:42 PDT] no ADS-B data program seen listening on port 30005 for 310 seconds, next check in 60s
[2022-05-07 11:42 PDT] logged in to FlightAware as user guest
[2022-05-07 11:42 PDT] my feeder ID is 25696bf6-752c-46f1-8848-1b31b2ee9f0f
[2022-05-07 11:42 PDT] no ADS-B data program seen listening on port 30005 for 11 seconds, next check in 60s
[2022-05-07 11:42 PDT] 0 msgs recv’d from dump1090 (0 in last 1m); 0 msgs sent to FlightAware
[2022-05-07 11:43 PDT] no ADS-B data program seen listening on port 30005 for 71 seconds, next check in 60s
[2022-05-07 11:44 PDT] no ADS-B data program seen listening on port 30005 for 131 seconds, next check in 60s
[2022-05-07 11:45 PDT] no ADS-B data program seen listening on port 30005 for 191 seconds, next check in 60s
[2022-05-07 11:46 PDT] manual update (user-initiated via their flightaware control page) requested by adept server
[2022-05-07 11:46 PDT] performing manual update, action: dump1090 restart_piaware
[2022-05-07 11:46 PDT] *** running command ‘/usr/lib/piaware/helpers/run-apt-get update’ and logging output
[2022-05-07 11:46 PDT] run-apt-get(1305): Get:2 http://flightaware.com/adsb/piaware/files/packages bullseye InRelease [1,860 B]
[2022-05-07 11:46 PDT] run-apt-get(1305): Get:1 http://flightaware.com/mirror/raspbian/raspbian bullseye InRelease [15.0 kB]
[2022-05-07 11:46 PDT] run-apt-get(1305): Get:3 http://flightaware.com/mirror/raspberrypi/debian bullseye InRelease [23.7 kB]
[2022-05-07 11:46 PDT] run-apt-get(1305): Get:4 http://flightaware.com/mirror/raspbian/raspbian bullseye/main armhf Packages [13.2 MB]
[2022-05-07 11:46 PDT] run-apt-get(1305): Get:6 http://flightaware.com/mirror/raspbian/raspbian bullseye/non-free armhf Packages [106 kB]
[2022-05-07 11:46 PDT] run-apt-get(1305): Get:5 http://flightaware.com/mirror/raspbian/raspbian bullseye/contrib armhf Packages [60.2 kB]
[2022-05-07 11:46 PDT] run-apt-get(1305): Get:8 http://flightaware.com/mirror/raspberrypi/debian bullseye/main armhf Packages [283 kB]
[2022-05-07 11:46 PDT] run-apt-get(1305): Get:7 http://flightaware.com/adsb/piaware/files/packages bullseye/piaware armhf Packages [6,366 B]
[2022-05-07 11:46 PDT] no ADS-B data program seen listening on port 30005 for 252 seconds, next check in 60s
[2022-05-07 11:46 PDT] run-apt-get(1305): Fetched 13.7 MB in 31s (437 kB/s)
[2022-05-07 11:47 PDT] run-apt-get(1305): Reading package lists…
[2022-05-07 11:47 PDT] *** running command ‘/usr/lib/piaware/helpers/run-apt-get upgrade-package dump1090-fa’ and logging output
[2022-05-07 11:47 PDT] run-apt-get(1507): Reading package lists…
[2022-05-07 11:47 PDT] run-apt-get(1507): Building dependency tree…
[2022-05-07 11:47 PDT] run-apt-get(1507): Reading state information…
[2022-05-07 11:47 PDT] run-apt-get(1507): 0 upgraded, 0 newly installed, 0 to remove and 53 not upgraded.
[2022-05-07 11:47 PDT] attempting to restart dump1090…
[2022-05-07 11:47 PDT] attempting to restart dump1090-fa using ‘systemctl --no-block try-restart dump1090-fa.service < /dev/null’…
[2022-05-07 11:47 PDT] run-apt-get(1507): dump1090-fa is already the newest version (7.2).
[2022-05-07 11:47 PDT] upgrade of dump1090-fa seemed to go OK
[2022-05-07 11:47 PDT] dump1090 restart appears to have been successful
[2022-05-07 11:47 PDT] update request complete
[2022-05-07 11:47 PDT] restarting piaware. hopefully i’ll be right back…
[2022-05-07 11:47 PDT] piaware (process 419) is exiting…
[2022-05-07 11:47 PDT] UAT support disabled by local configuration setting: uat-receiver-type
[2022-05-07 11:47 PDT] my feeder ID is 25696bf6-752c-46f1-8848-1b31b2ee9f0f
[2022-05-07 11:47 PDT] no ADS-B data program seen listening on port 30005 for 3 seconds, next check in 60s
[2022-05-07 11:47 PDT] logged in to FlightAware as user prion
[2022-05-07 11:47 PDT] site statistics URL: prion ADS-B Feeder Statistics - FlightAware
[2022-05-07 11:48 PDT] 0 msgs recv’d from dump1090; 0 msgs sent to FlightAware
[2022-05-07 11:48 PDT] no ADS-B data program seen listening on port 30005 for 64 seconds, next check in 60s
[2022-05-07 11:49 PDT] performing manual update, action: piaware
[2022-05-07 11:49 PDT] manual update (user-initiated via their flightaware control page) requested by adept server
[2022-05-07 11:49 PDT] *** running command ‘/usr/lib/piaware/helpers/run-apt-get update’ and logging output
[2022-05-07 11:49 PDT] run-apt-get(1593): Hit:2 http://flightaware.com/adsb/piaware/files/packages bullseye InRelease
[2022-05-07 11:49 PDT] run-apt-get(1593): Hit:3 http://flightaware.com/mirror/raspberrypi/debian bullseye InRelease
[2022-05-07 11:49 PDT] run-apt-get(1593): Hit:1 http://flightaware.com/mirror/raspbian/raspbian bullseye InRelease
[2022-05-07 11:49 PDT] no ADS-B data program seen listening on port 30005 for 124 seconds, next check in 60s
[2022-05-07 11:49 PDT] run-apt-get(1593): Reading package lists…
[2022-05-07 11:49 PDT] *** running command ‘/usr/lib/piaware/helpers/run-apt-get upgrade-package piaware-release’ and logging output
[2022-05-07 11:49 PDT] run-apt-get(1770): Reading package lists…
[2022-05-07 11:49 PDT] run-apt-get(1770): Building dependency tree…
[2022-05-07 11:49 PDT] run-apt-get(1770): Reading state information…
[2022-05-07 11:49 PDT] run-apt-get(1770): 0 upgraded, 0 newly installed, 0 to remove and 53 not upgraded.
[2022-05-07 11:49 PDT] upgrade of piaware-release seemed to go OK
[2022-05-07 11:49 PDT] update request complete
[2022-05-07 11:49 PDT] restarting piaware. hopefully i’ll be right back…
[2022-05-07 11:49 PDT] piaware (process 1544) is exiting…
[2022-05-07 11:49 PDT] piaware (process 1544) is shutting down because it received a shutdown signal (SIGTERM) from the system…
[2022-05-07 11:49 PDT] UAT support disabled by local configuration setting: uat-receiver-type
[2022-05-07 11:49 PDT] logged in to FlightAware as user prion
[2022-05-07 11:49 PDT] no ADS-B data program seen listening on port 30005 for 3 seconds, next check in 60s
[2022-05-07 11:49 PDT] my feeder ID is 25696bf6-752c-46f1-8848-1b31b2ee9f0f
[2022-05-07 11:49 PDT] site statistics URL: prion ADS-B Feeder Statistics - FlightAware
[2022-05-07 11:50 PDT] 0 msgs recv’d from dump1090; 0 msgs sent to FlightAware
[2022-05-07 11:50 PDT] no ADS-B data program seen listening on port 30005 for 63 seconds, next check in 60s
[2022-05-07 11:51 PDT] no ADS-B data program seen listening on port 30005 for 124 seconds, next check in 60s
[2022-05-07 11:52 PDT] no ADS-B data program seen listening on port 30005 for 184 seconds, next check in 60s
[2022-05-07 11:53 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 11:53 PDT] multilateration data requested
[2022-05-07 11:54 PDT] multilateration data requested
[2022-05-07 11:54 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 11:54 PDT] attempting to restart dump1090-fa using ‘systemctl --no-block try-restart dump1090-fa.service < /dev/null’…
[2022-05-07 11:54 PDT] attempting to restart skyaware978…
[2022-05-07 11:54 PDT] skyaware978 restart appears to have been successful
[2022-05-07 11:54 PDT] logged in to FlightAware as user prion
[2022-05-07 11:54 PDT] no ADS-B data program seen listening on port 30005 for 304 seconds, next check in 60s
[2022-05-07 11:55 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 11:55 PDT] 0 msgs recv’d from dump1090 (0 in last 5m); 0 msgs sent to FlightAware
[2022-05-07 11:55 PDT] attempting to start dump1090…
[2022-05-07 11:55 PDT] no ADS-B data program seen listening on port 30005 for 365 seconds, trying to start it…
[2022-05-07 11:55 PDT] attempting to start dump1090-fa using ‘systemctl --no-block restart dump1090-fa.service < /dev/null’…
[2022-05-07 11:55 PDT] dump1090 start appears to have been successful
[2022-05-07 11:56 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 11:56 PDT] no ADS-B data program seen listening on port 30005 for 10 seconds, next check in 60s
[2022-05-07 11:56 PDT] attempting to restart dump1090…
[2022-05-07 11:56 PDT] performing manual update, action: restart_dump1090
[2022-05-07 11:56 PDT] dump1090 restart appears to have been successful
[2022-05-07 11:56 PDT] attempting to restart dump1090-fa using ‘systemctl --no-block try-restart dump1090-fa.service < /dev/null’…
[2022-05-07 11:56 PDT] update request complete
[2022-05-07 11:57 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 11:57 PDT] no ADS-B data program seen listening on port 30005 for 71 seconds, next check in 60s
[2022-05-07 11:58 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 11:58 PDT] no ADS-B data program seen listening on port 30005 for 131 seconds, next check in 60s
[2022-05-07 11:59 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 11:59 PDT] no ADS-B data program seen listening on port 30005 for 191 seconds, next check in 60s
[2022-05-07 12:00 PDT] performing manual update, action: reboot
[2022-05-07 12:00 PDT] rebooting…
[2022-05-07 12:00 PDT] update request complete
[2022-05-07 12:00 PDT] manual update (user-initiated via their flightaware control page) requested by adept server
[2022-05-07 12:00 PDT] multilateration data no longer required, disabling mlat client
[2022-05-07 12:00 PDT] piaware (process 1797) is exiting…
[2022-05-07 12:00 PDT] piaware (process 1797) is shutting down because it received a shutdown signal (SIGTERM) from the system…
[2022-05-07 12:01 PDT] adept reported location: 47.09565, -122.74196, 150ft AMSL
[2022-05-07 12:01 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:01 PDT] site statistics URL: prion ADS-B Feeder Statistics - FlightAware
[2022-05-07 12:01 PDT] my feeder ID is 25696bf6-752c-46f1-8848-1b31b2ee9f0f
[2022-05-07 12:01 PDT] 0 msgs recv’d from dump1090; 0 msgs sent to FlightAware
[2022-05-07 12:02 PDT] no ADS-B data program seen listening on port 30005 for 70 seconds, next check in 60s
[2022-05-07 12:02 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:02 PDT] multilateration data requested
[2022-05-07 12:02 PDT] site statistics URL: prion ADS-B Feeder Statistics - FlightAware
[2022-05-07 12:03 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:04 PDT] no ADS-B data program seen listening on port 30005 for 191 seconds, next check in 60s
[2022-05-07 12:04 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:05 PDT] no ADS-B data program seen listening on port 30005 for 251 seconds, next check in 60s
[2022-05-07 12:06 PDT] no ADS-B data program seen listening on port 30005 for 311 seconds, next check in 60s
[2022-05-07 12:06 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:07 PDT] attempting to start dump1090…
[2022-05-07 12:07 PDT] no ADS-B data program seen listening on port 30005 for 371 seconds, trying to start it…
[2022-05-07 12:07 PDT] attempting to start dump1090-fa using ‘systemctl --no-block restart dump1090-fa.service < /dev/null’…
[2022-05-07 12:07 PDT] no ADS-B data program seen listening on port 30005 for 10 seconds, next check in 60s
[2022-05-07 12:07 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:08 PDT] no ADS-B data program seen listening on port 30005 for 71 seconds, next check in 60s
[2022-05-07 12:08 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:09 PDT] no ADS-B data program seen listening on port 30005 for 131 seconds, next check in 60s
[2022-05-07 12:09 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:10 PDT] no ADS-B data program seen listening on port 30005 for 191 seconds, next check in 60s
[2022-05-07 12:10 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:11 PDT] no ADS-B data program seen listening on port 30005 for 251 seconds, next check in 60s
[2022-05-07 12:11 PDT] 0 msgs recv’d from dump1090 (0 in last 5m); 0 msgs sent to FlightAware
[2022-05-07 12:12 PDT] no ADS-B data program seen listening on port 30005 for 312 seconds, next check in 60s
[2022-05-07 12:12 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:13 PDT] attempting to start dump1090…
[2022-05-07 12:13 PDT] no ADS-B data program seen listening on port 30005 for 372 seconds, trying to start it…
[2022-05-07 12:13 PDT] attempting to start dump1090-fa using ‘systemctl --no-block restart dump1090-fa.service < /dev/null’…
[2022-05-07 12:13 PDT] *** running command ‘/usr/lib/piaware/helpers/run-apt-get update’ and logging output
[2022-05-07 12:13 PDT] manual update (user-initiated via their flightaware control page) requested by adept server
[2022-05-07 12:13 PDT] performing manual update, action: dump1090 restart_piaware
[2022-05-07 12:13 PDT] run-apt-get(1127): Hit:1 http://flightaware.com/mirror/raspbian/raspbian bullseye InRelease
[2022-05-07 12:13 PDT] no ADS-B data program seen listening on port 30005 for 11 seconds, next check in 60s
[2022-05-07 12:13 PDT] run-apt-get(1127): Reading package lists…
[2022-05-07 12:13 PDT] *** running command ‘/usr/lib/piaware/helpers/run-apt-get upgrade-package dump1090-fa’ and logging output
[2022-05-07 12:14 PDT] run-apt-get(1306): Reading package lists…
[2022-05-07 12:14 PDT] run-apt-get(1306): Building dependency tree…
[2022-05-07 12:14 PDT] run-apt-get(1306): Reading state information…
[2022-05-07 12:14 PDT] run-apt-get(1306): 0 upgraded, 0 newly installed, 0 to remove and 53 not upgraded.
[2022-05-07 12:14 PDT] attempting to restart dump1090…
[2022-05-07 12:14 PDT] restarting piaware. hopefully i’ll be right back…
[2022-05-07 12:14 PDT] update request complete
[2022-05-07 12:14 PDT] dump1090 restart appears to have been successful
[2022-05-07 12:14 PDT] piaware (process 415) is exiting…
[2022-05-07 12:14 PDT] UAT support disabled by local configuration setting: uat-receiver-type
[2022-05-07 12:14 PDT] no ADS-B data program seen listening on port 30005 for 4 seconds, next check in 60s
[2022-05-07 12:14 PDT] my feeder ID is 25696bf6-752c-46f1-8848-1b31b2ee9f0f
[2022-05-07 12:14 PDT] adept reported location: 47.09565, -122.74196, 150ft AMSL
[2022-05-07 12:14 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:14 PDT] 0 msgs recv’d from dump1090; 0 msgs sent to FlightAware
[2022-05-07 12:15 PDT] no ADS-B data program seen listening on port 30005 for 65 seconds, next check in 60s
[2022-05-07 12:15 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:16 PDT] no ADS-B data program seen listening on port 30005 for 125 seconds, next check in 60s
[2022-05-07 12:16 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:17 PDT] no ADS-B data program seen listening on port 30005 for 185 seconds, next check in 60s
[2022-05-07 12:17 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:19 PDT] no ADS-B data program seen listening on port 30005 for 305 seconds, next check in 60s
[2022-05-07 12:19 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:19 PDT] 0 msgs recv’d from dump1090 (0 in last 5m); 0 msgs sent to FlightAware
[2022-05-07 12:20 PDT] attempting to start dump1090-fa using ‘systemctl --no-block restart dump1090-fa.service < /dev/null’…
[2022-05-07 12:20 PDT] dump1090 start appears to have been successful
[2022-05-07 12:20 PDT] attempting to start dump1090…
[2022-05-07 12:20 PDT] no ADS-B data program seen listening on port 30005 for 366 seconds, trying to start it…
[2022-05-07 12:20 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:21 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:22 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:22 PDT] no ADS-B data program seen listening on port 30005 for 131 seconds, next check in 60s
[2022-05-07 12:23 PDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-05-07 12:23 PDT] no ADS-B data program seen listening on port 30005 for 191 seconds, next check in 60s
