hi,
I have been a feeder for almost a decade but never been so frustrated with PiAware.
I use a raspberry 4v 2, my sd card crashed (again after 2 years) so I had to reinstall a clean PiAware image. I used 10.1, flashed the image to the sd, edit the piaware-config.txt and also enable ssh, so far so good.
Out of the box and for unknown reasons the boot sequences takes way longer than previous version. After few minutes I was finally able to ssh to the box, the connexion was EXTREMLY slow. Ethernet is enable, the I decided to disconnect the cable and try wifi. Same issue, I decided to be patient and too almost 60 seconds for login and password.
I just wanted to make sure the packages are updated and did an apt-get update then upgrade. Rebooted because there was some issues with 1090 feeder. After the reboot, same: takes forever to boot, seeing the service starting at the bottom left, then randomly restart by itself…
it’s the second time I flash the sdcard and same issue, is it the sd card? Unlikely brand new 128Go sd, I even tried a second sd card.
Due to the boot loop of course I can’t see the logs…
PS: instead of having a big logo during boot would have been great to display verbose boot so we can see details of the boot sequence.
