I know this has been mentioned before and I thought I’d found a solution but clearly I haven’t.
My range in the performance graphs is capped at 269.9nm (500km).
I’m using the ADS-B Receiver project script and am using dump1090-mutability.
I’ve set MAX_RANGE=“700” in /etc/default/dump1090-mutability and although I don’t think it actually does anything, I’ve set -z “$MAX_RANGE” ] && MAX_RANGE=700 in /etc/init.d/dump1090-mutability
The obvious answer is that I never see anything further than 269.9nm away. That’s not correct though, my VRS heatmap does show flights further away than that and I do see them on the map on a fairly regular basis. 500km is too precise a number for that to be my actual peak range.
If I recall, MAX_RANGE= is used to pare out spurious entries that are clearly off the wall. I have mine set at MAX_RANGE=350.
If you want to test the effect change MAX_RANGE=200 for a while and see what happens.
I also have the same issue despite seeing targets on the the map over water at 320nm. Please report your findings and command line required to change max range.
Something like “rrdtool tune /path/to/rrd/file.rrd --maximum value:750000”
I don’t know where the rrd files are stored on your setup.
You may need to stop/start collectd.
Max range of dump1090-fa is configured to be 360NM (not 320) in the piaware sdcard image, and 300NM in a package install (I should probably fix that to be consistent). You can configure this in /etc/default/dump1090-fa for a package install. It is not configurable in a piaware sdcard install.
The commands you are trying are for use with systems that gather stats via collectd/rrdtool. If you not using such a setup, of course they will do nothing. And they only affect stats collection, not what dump1090 does.
Just to confirm, if I put Raspbian on a card, then install the PA package, then edit /etc/default/dump1090-fa with a higher max range, the aircraft that my setup sees beyond 360nm will then be included in my aircraft (hulls) seen stats and be shown on the map?
Will wittrup’s gain optimization script and The ADSB Receiver Project graphs and maps still work with a package install?
Local display yes. The feed to FlightAware has a hardcoded range limit that is not configurable (this is deliberate). For other software you would need to ask the maintainers of that software not me.
Generally we trust the planeplotter data less than data direct from a piaware; IIRC there is a more restrictive range/plausibility limit on planeplotter feeds compared to piaware feeds for that reason
If I change to PP, can I build on top of my previous stats, or will I have to start afresh with zero stats on a new site?
It will be a new site.
I would encourage you to look at it from the point of view of data quality, not maximizing stats. We don’t process extremely long range data because it is less reliable.
