[OUTDATED] Repository https://abcd567a.github.io/ppa/piaware error 404 - Cannot update
Did only happens on the 10th of Jan. (I update regularly each day), went away and the temp.-warnings ad reboots never reappeared afterwards:
The cache doesn’t mean anything, it’s normal to use up all the available memory.
That’s normal linux operation.
I suppose i misread what you wrote … you noticed in hte graphs but didn’t mean that graphs1090 itself was using the memroy.
Consider using SSH instead of connecting a screen via HDMI …
Also if you don’t have the original Raspberry Pi power supply, that’s the one to get.
I use SSH also but for some things its easier to use the screen eg trying to select text from the terminal to paste in here is sometimes hard to do with the laptop on SSH. It connecting internally to the pi with a ribbon cable though, not the HDMI port. Power supply is original
It doesn’t say this unless there are power issues.
Something with the hardware isn’t quite right, be it power supply or pi.
Ok thanks. Well it’s not the charger unless its faulty, but its less than 2 months old. Have left the back off the pi case for ventilation and the pi didn’t crash last night… could that be it, or I should look for another cause?
Chargers are not suitable as a power supply for the RPi.
Using an original Raspberry Pi brand power supply is heavily recommended.
Its the original Raspberry Pi brand power supply… sorry for the confusion
Official Raspberry Pi Power Supply, DC 5.1 V, 3.0 A, with C type connector for RPi Model 4, with European Pin - available in two colors, black & white
Bought a kit with pi, power supply, etc included. The power has a USB type A plug inside it, but the one you show is hardwired. I’m quite sure mine is also original but should I get the hardwired version instead?
I have purchased 2 RPi model 4 + Power Supply Adaptor from Raspberry Pi’s authorised agent for Canada. Both adaptors are hard-wired, no A type USB plug.
Seems the seller from whome you purchased the kit has sold you a counterfeit, which he purchased cheaper than genuine one.
Better buy directly from Raspberry Pi or their authorized agent.
https://www.raspberrypi.com/products/type-c-power-supply/
I do have two Raspberry 4 and for both i ordered the original charger which are both hard wired.
Make sure that the Raspberry logo is engraved on top of it. Many called “original” do not have it and are third-party Not sure if there are original chargers available where the cable can be detached
That is mine:
Ok, thanks. Found one locally original (https://www.bgrsolutions.net/product/fuente-raspberry-pi4-usb-c-5-1v-3a-blanco-1873421/).Will collect tomorrow.
That is the one i have and where i’ve taken the picture of.
One of my Raspberries is running overclocked at 2 GHz with that - no issues at all
I got the original Raspberry Pi adapter last night and replaced the other one. There was no crash overnight so fingers crossed it solved the crashing problem. Here is the new log info. Does it show that the problem with the power is solved?
pi@raspberrypi:~ $ tail -n 100 /var/log/syslog
Jan 26 10:40:59 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:40:59#033[35m]#033[0m Data received: 18.9 KB
Jan 26 10:41:30 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:41:30#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:41:30 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:41:30#033[35m]#033[0m Packets sent in the last 30 seconds: 524, Total packets sent since startup: 266799
Jan 26 10:41:30 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:41:30#033[35m]#033[0m Data sent: 8.0 MB
Jan 26 10:41:30 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:41:30#033[35m]#033[0m Data received: 18.9 KB
Jan 26 10:42:01 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:42:01#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:42:01 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:42:01#033[35m]#033[0m Packets sent in the last 30 seconds: 510, Total packets sent since startup: 267309
Jan 26 10:42:01 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:42:01#033[35m]#033[0m Data sent: 8.0 MB
Jan 26 10:42:01 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:42:01#033[35m]#033[0m Data received: 19.0 KB
Jan 26 10:42:32 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:42:32#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:42:32 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:42:32#033[35m]#033[0m Packets sent in the last 30 seconds: 477, Total packets sent since startup: 267786
Jan 26 10:42:32 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:42:32#033[35m]#033[0m Data sent: 8.0 MB
Jan 26 10:42:32 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:42:32#033[35m]#033[0m Data received: 19.0 KB
Jan 26 10:43:03 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:43:03#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:43:03 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:43:03#033[35m]#033[0m Packets sent in the last 30 seconds: 645, Total packets sent since startup: 268431
Jan 26 10:43:03 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:43:03#033[35m]#033[0m Data sent: 8.0 MB
Jan 26 10:43:03 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:43:03#033[35m]#033[0m Data received: 19.0 KB
Jan 26 10:43:34 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:43:34#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:43:34 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:43:34#033[35m]#033[0m Packets sent in the last 30 seconds: 700, Total packets sent since startup: 269131
Jan 26 10:43:34 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:43:34#033[35m]#033[0m Data sent: 8.0 MB
Jan 26 10:43:34 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:43:34#033[35m]#033[0m Data received: 19.0 KB
Jan 26 10:44:05 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:44:05#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:44:05 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:44:05#033[35m]#033[0m Packets sent in the last 30 seconds: 540, Total packets sent since startup: 269671
Jan 26 10:44:05 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:44:05#033[35m]#033[0m Data sent: 8.1 MB
Jan 26 10:44:05 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:44:05#033[35m]#033[0m Data received: 19.0 KB
Jan 26 10:44:36 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:44:36#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:44:36 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:44:36#033[35m]#033[0m Packets sent in the last 30 seconds: 474, Total packets sent since startup: 270145
Jan 26 10:44:36 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:44:36#033[35m]#033[0m Data sent: 8.1 MB
Jan 26 10:44:36 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:44:36#033[35m]#033[0m Data received: 19.0 KB
Jan 26 10:45:07 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:45:07#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:45:07 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:45:07#033[35m]#033[0m Packets sent in the last 30 seconds: 555, Total packets sent since startup: 270700
Jan 26 10:45:07 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:45:07#033[35m]#033[0m Data sent: 8.1 MB
Jan 26 10:45:07 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:45:07#033[35m]#033[0m Data received: 19.0 KB
Jan 26 10:45:38 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:45:38#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:45:38 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:45:38#033[35m]#033[0m Packets sent in the last 30 seconds: 578, Total packets sent since startup: 271278
Jan 26 10:45:38 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:45:38#033[35m]#033[0m Data sent: 8.1 MB
Jan 26 10:45:38 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:45:38#033[35m]#033[0m Data received: 19.0 KB
Jan 26 10:46:09 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:46:09#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:46:09 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:46:09#033[35m]#033[0m Packets sent in the last 30 seconds: 571, Total packets sent since startup: 271849
Jan 26 10:46:09 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:46:09#033[35m]#033[0m Data sent: 8.1 MB
Jan 26 10:46:09 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:46:09#033[35m]#033[0m Data received: 19.0 KB
Jan 26 10:46:32 raspberrypi kernel: [41423.671054] edt_ft5x06 10-0038: Unable to fetch data, error: -121
Jan 26 10:46:33 raspberrypi kernel: [41424.769439] i2c-bcm2835 fe205000.i2c: i2c transfer timed out
Jan 26 10:46:33 raspberrypi kernel: [41424.769465] edt_ft5x06 10-0038: Unable to fetch data, error: -110
Jan 26 10:46:33 raspberrypi kernel: [41424.769518] edt_ft5x06 10-0038: Unable to fetch data, error: -5
Jan 26 10:46:38 raspberrypi rbfeeder[744]: Wed Jan 26 10:46:38 2022 Receiver status: connected
Jan 26 10:46:38 raspberrypi rbfeeder[744]: Wed Jan 26 10:46:38 2022 Server status: ready
Jan 26 10:46:38 raspberrypi rbfeeder[744]: Wed Jan 26 10:46:38 2022 Receiver: 80.4 msg/s received 23.4 msg/s processed (29%)
Jan 26 10:46:38 raspberrypi rbfeeder[744]: Wed Jan 26 10:46:38 2022 Server: 0.0 kB/s from server 0.2kB/s TCP to server 0.0kB/s UDP to server
Jan 26 10:46:38 raspberrypi rbfeeder[744]: Wed Jan 26 10:46:38 2022 Results: 1.3 positions/minute
Jan 26 10:46:38 raspberrypi rbfeeder[744]: Wed Jan 26 10:46:38 2022 Aircraft: 3 of 3 Mode S, 7 of 7 ADS-B used
Jan 26 10:46:40 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:46:40#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:46:40 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:46:40#033[35m]#033[0m Packets sent in the last 30 seconds: 617, Total packets sent since startup: 272466
Jan 26 10:46:40 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:46:40#033[35m]#033[0m Data sent: 8.1 MB
Jan 26 10:46:40 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:46:40#033[35m]#033[0m Data received: 19.0 KB
Jan 26 10:47:11 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:47:11#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:47:11 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:47:11#033[35m]#033[0m Packets sent in the last 30 seconds: 569, Total packets sent since startup: 273035
Jan 26 10:47:11 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:47:11#033[35m]#033[0m Data sent: 8.2 MB
Jan 26 10:47:11 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:47:11#033[35m]#033[0m Data received: 19.0 KB
Jan 26 10:47:42 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:47:42#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:47:42 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:47:42#033[35m]#033[0m Packets sent in the last 30 seconds: 485, Total packets sent since startup: 273520
Jan 26 10:47:42 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:47:42#033[35m]#033[0m Data sent: 8.2 MB
Jan 26 10:47:42 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:47:42#033[35m]#033[0m Data received: 19.1 KB
Jan 26 10:48:03 raspberrypi vncserver-x11[723,root]: TurnDgram: Received ChannelBind error (code=403)
Jan 26 10:48:03 raspberrypi vncserver-x11[723,root]: HostedRendezvous: Connection to [hLEXeV-wX43L-AkcKBR] is from user “cbdagency@gmail.com
Jan 26 10:48:03 raspberrypi vncserver-x11[723,root]: Connections: connected: cbdagency@gmail.com (from 192.168.1.133::63648)
Jan 26 10:48:07 raspberrypi adsbexchange-mlat[1748]: Receiver: connected 79.9 msg/s received 21.9 msg/s processed (27%)
Jan 26 10:48:07 raspberrypi adsbexchange-mlat[1748]: Server: ready 0.0 kB/s from server 0.1 kB/s to server
Jan 26 10:48:07 raspberrypi adsbexchange-mlat[1748]: Results: 0.0 positions/minute
Jan 26 10:48:07 raspberrypi adsbexchange-mlat[1748]: Aircraft: 0 of 6 Mode S, 4 of 5 ADS-B used
Jan 26 10:48:12 raspberrypi vncserver-x11[723,root]: Connections: authenticated: cbdagency@gmail.com (from 192.168.1.133::63648), as cbdagency@gmail.com (d permissions)
Jan 26 10:48:13 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:48:13#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:48:13 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:48:13#033[35m]#033[0m Packets sent in the last 30 seconds: 547, Total packets sent since startup: 274067
Jan 26 10:48:13 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:48:13#033[35m]#033[0m Data sent: 8.2 MB
Jan 26 10:48:13 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:48:13#033[35m]#033[0m Data received: 19.1 KB
Jan 26 10:48:14 raspberrypi dbus-daemon[407]: [system] Activating via systemd: service name=‘org.freedesktop.ColorManager’ unit=‘colord.service’ requested by ‘:1.41’ (uid=0 pid=13265 comm="/usr/sbin/cupsd -l ")
Jan 26 10:48:14 raspberrypi systemd[1]: Starting Manage, Install and Generate Color Profiles…
Jan 26 10:48:14 raspberrypi colord[24006]: failed to get edid data: EDID length is too small
Jan 26 10:48:14 raspberrypi dbus-daemon[407]: [system] Successfully activated service ‘org.freedesktop.ColorManager’
Jan 26 10:48:14 raspberrypi systemd[1]: Started Manage, Install and Generate Color Profiles.
Jan 26 10:48:44 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:48:44#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:48:44 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:48:44#033[35m]#033[0m Packets sent in the last 30 seconds: 554, Total packets sent since startup: 274621
Jan 26 10:48:44 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:48:44#033[35m]#033[0m Data sent: 8.2 MB
Jan 26 10:48:44 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:48:44#033[35m]#033[0m Data received: 19.1 KB
Jan 26 10:49:15 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:49:15#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:49:15 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:49:15#033[35m]#033[0m Packets sent in the last 30 seconds: 525, Total packets sent since startup: 275146
Jan 26 10:49:15 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:49:15#033[35m]#033[0m Data sent: 8.2 MB
Jan 26 10:49:15 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:49:15#033[35m]#033[0m Data received: 19.1 KB
Jan 26 10:49:46 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:49:46#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:49:46 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:49:46#033[35m]#033[0m Packets sent in the last 30 seconds: 519, Total packets sent since startup: 275665
Jan 26 10:49:46 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:49:46#033[35m]#033[0m Data sent: 8.2 MB
Jan 26 10:49:46 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:49:46#033[35m]#033[0m Data received: 19.1 KB
Jan 26 10:50:17 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:50:17#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:50:17 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:50:17#033[35m]#033[0m Packets sent in the last 30 seconds: 437, Total packets sent since startup: 276102
Jan 26 10:50:17 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:50:17#033[35m]#033[0m Data sent: 8.3 MB
Jan 26 10:50:17 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:50:17#033[35m]#033[0m Data received: 19.1 KB
Jan 26 10:50:48 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:50:48#033[35m]#033[0m ******** Statistics updated every 30 seconds ********
Jan 26 10:50:48 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:50:48#033[35m]#033[0m Packets sent in the last 30 seconds: 433, Total packets sent since startup: 276535
Jan 26 10:50:48 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:50:48#033[35m]#033[0m Data sent: 8.3 MB
Jan 26 10:50:48 raspberrypi rbfeeder[662]: #033[35m[#033[33m2022-01-26 10:50:48#033[35m]#033[0m Data received: 19.1 KB
It doesn’t show anything as it’s just rbfeeder log spam.
I’d assume power is now fine, no real need to specifically check.
Now that you have clean power, start over because you probably have some file corruption …
https://github.com/wiedehopf/adsb-wiki/wiki/Raspbian-Lite:-ADS-B-receiver
Or continue with the current card at your own peril :slight_smile:
Which can be disabled by setting disable_log=1 in rbfeeder.ini and restarting the service
I am doing this immediately once it’s clear the service is running properly.
Otherwise the “spam” is massive in the logs.
Ok thanks for checking. If nothing else goes wrong I wont reinstall on this SD but might try on another one as would like a spare working card in case of emergency. I read somewhere that it shouldn’t be more than 32GB (something to do with the limitations of FAT32 system)… is that correct? Assuming no more crashes how can I just clone the existing SD?
Thankyou. The feeder logs get replaced automatically every day or two, right?
Please dont do this, as existing SD has already gone through lot of abuses. Better write a fresh and latest image on another microSD card and install all feeders on it afresh. Keep existing as backup.
Depends on how log rotation is set up. every day the logs are zipped and replaced by one for the current day. After xx days the oldest are deleted.
If i am not wrong, the default is seven days.
