@valemaio
@raoulduke881
@foxhunter
My repository did not provide upgrade, it was static, just a stop-gap arrangement till official packages are released by Flightaware. Because ver 6.1 is out-dated now, I have deleted that repository.
Those who have installed ver 6.1 packages from my PPA have 2 options:
(1) Wait for official release of ver 7.0 packages from Flightaware.
(2) Upgrade to “Unofficial” ver 7.0 packages which I have built and uploaded to new PPA I have created yesterday (please see method given below).
Please note that when Flightaware releases “Official” ver 7.0, you will need to delete my repository from your Pi by following command:
sudo rm /etc/apt/sources.list.d/abcd567a.list
After that, add Flightaware repository and “Official” packages by method given at https://flightaware.com/adsb/piaware/install
How To Install Piaware 7.0 armhf and arm64 Packages from my Personal Package Archive (PPA):
(1) Please note that first two commands are very long and may be wrapped by forum into two lines. Copy these in full
(2) Please dont copy $ at start of command. It is put there to indicates start of a new command. Any line NOT starting with $ is actually continuation of the line immediately above it
$ sudo wget -O - https://raw.githubusercontent.com/abcd567a/ppa/main/KEY.gpg | sudo apt-key add -
$ sudo wget -O /etc/apt/sources.list.d/abcd567a.list https://raw.githubusercontent.com/abcd567a/ppa/main/abcd567a.list
$ sudo apt update
$ sudo apt install piaware
$ sudo apt install dump1090-fa
$ sudo apt install piaware-web
$ sudo piaware-config feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
$ sudo reboot
Additional steps if you have already installed (or want to install) dump978-fa
$ sudo apt install dump978-fa
$ sudo piaware-config uat-receiver-type sdr
Serialize Dongles to 8-digit serial numbers 00001090 and 00000978
Configure dump1090-fa & dump978-fa to use the dongles with above serial numbers
$ sudo sed -i 's/^RECEIVER_SERIAL=.*/RECEIVER_SERIAL=00001090/' /etc/default/dump1090-fa
$ sudo sed -i 's/driver=rtlsdr[^ ]* /driver=rtlsdr,serial=00000978 /' /etc/default/dump978-fa
$ sudo reboot
NOTE:
If you decide to install the unofficial version now, then please replace these by official packages when these are made available by Flightaware here:
When installing official version, dont forget to first delete my repository from your Pi’s apt sources list by following command:
sudo apt update
