I just received the Flight Aware ADS-B N-Type Antenna 26", but it’s completely different from all the images on the internet. I received a Grey antenna with the brackets etc, but it does not have the FlightAware logo on it. It has a white sticker on it which says “F:1060 - 1120MHz”.
The images on the above sites are lacking detail on the sticker, but the color is different.
I’m unsure if you bought a “dead sparrow” (NL: dode mus), but it doesn’t look like the official FlightAware antenna indeed.
You picture the antenna is grey.
But it looks like it’s high quality so maybe the original supplier making the Flightaware antenna had a shortage in the original color?
@esmathews
Does your supplier vary the color of the antenna?
I’ve setup my “pro stuff” in 2016, week 26.
Ordered at Amazon, with the orange FlightAware stick, the light blue FA filter and the official olive green FA antenna. Replacing the cut whip antenna and el cheapo dongle.
Around that time I made this screenshot to show what it did to my performance → Moving to a little more pro stuff (end of June 2016) | Flickr
I hope to receive the 2019 dark blue FA filter this week, to filter the GSM900 signals that surround me.
I currently have a cheap blue aliexpress dongle and a whip antenna which I cut. You can see the performance on my FlightAware page: https://flightaware.com/adsb/stats/user/BLFA Which is not too bad.
The Raspberry Pi 3B+ sits in my attic, the whip antenna is mounted outside, 2 meters above my roof on a PVC pipe (I designed and 3D printed a custom PVC pipe holder which I screwed into the metal roof window enclusure).
I hope I can see more than 100 planes at the same time with the new antenna. I also bought a FlightAware Pro Stick Plus (Blue) at the same seller, but have to wait for the 5 meter cable to get delivered by regular mail, probably somewhere today.
Antenna seems to perform fine from what I see there!
“More than 100 planes” - mission accomplished!
I get only half of that, placed inside on the second floor and surrounded by high rise buildings.
Nevertheless I think SOS Solutions should not sell the antenna as a FlightAware branded one…
And where did you buy that cable? Does it have N & SMA connectors already fitted?
I ask because after only 3 years I looked at the coax that was delivered with the Amazon FA-kit.
It turns out to be “YangYang” RG-58/U 50ohm (3m / 10ft):
I’m a big fan of Messi & Paoloni coax - Their 7mm cable is slightly lower loss than Aircell 7. However, for any decent length, I’d recommend their Ultraflex 10 which is 10mm diameter and quotes 13.81dB loss for a 100m length at 1GHz. They also have a Hyperflex range which is a bit more flexible, fractionally lower loss and slightly more expensive.
My preferred supplier is WiMo - I’ve bought from them quite a few times. Even with the cost of shipping to the UK, it’s cheaper from them than it is from UK suppliers.
/edit - I won’t use any other make coax now. I even use Ultraflex 7 for patch leads!
