I just found the following listed as a “Presidential TFR” covering Teterboro airport, TEB, just across the Hudson from New York. I’m puzzled by two things.
Why is Obama flying into TEB? I would expect him to use EWR or JFK, so he could bring the big plane (VC-25A, the modified 747 commonly referred to as Air Force One). If he is flying into TEB, what aircraft is he using? AFAIK, the gulfstreams are the only Air Force VIP aircraft that can operate there. Perhaps it’s another date night with Michelle?
The TFR was listed twice, once under ZNY, (where it belongs), and once under ZBW (boston center). Come again?
OCTOBER 6, 2010 LOCAL. PURSUANT TO 49
USC 40103(B), THE FEDERAL AVIATION ADMINISTRATION (FAA) CLASSIFIES
THE AIRSPACE DEFINED IN THIS NOTAM AS ‘NATIONAL DEFENSE AIRSPACE’.
PILOTS WHO DO NOT ADHERE TO THE FOLLOWING PROCEDURES MAY BE
INTERCEPTED, DETAINED AND INTERVIEWED BY LAW ENFORCEMENT/SECURITY
PERSONNEL. ANY OF THE FOLLOWING ADDITIONAL ACTIONS MAY ALSO BE
TAKEN AGAINST A PILOT WHO DOES NOT COMPLY WITH THE REQUIREMENTS OR
ANY SPECIAL INSTRUCTIONS OR PROCEDURES ANNOUNCED IN THIS NOTAM:
A) THE FAA MAY TAKE ADMINISTRATIVE ACTION, INCLUDING IMPOSING CIVIL
PENALTIES AND THE SUSPENSION OR REVOCATION OF AIRMEN CERTIFICATES;
OR
B) THE UNITED STATES GOVERNMENT MAY PURSUE CRIMINAL CHARGES,
INCLUDING CHARGES UNDER TITLE 49 OF THE UNITED STATES CODE,
SECTION 46307; OR
C) THE UNITED STATES GOVERNMENT MAY USE DEADLY FORCE AGAINST THE
AIRBORNE AIRCRAFT, IF IT IS DETERMINED THAT THE AIRCRAFT POSES AN
IMMINENT SECURITY THREAT.
PURSUANT TO TITLE 14, SECTION 91.141 OF THE CODE OF FEDERAL
REGULATIONS, AIRCRAFT FLIGHT OPERATIONS ARE PROHIBITED
WITHIN A 30 NMR OF 404121N/0741022W OR THE TEB219010.8 UP TO BUT
END PART 1 OF 5. WIE UNTIL UFN. CREATED: 04 OCT 15:55 2010
(Map it)
FDC 0/9203 - PART 2 OF 5 FLIGHT RESTRICTIONS CRESSKILL, NEW JERSEY
NOT INCLUDING 18000 FT MSL
EFFECTIVE 1010062045 UTC (1645 LOCAL 10/06/10) UNTIL 1010062200 UTC
(1800 LOCAL 10/06/10).
WITHIN A 10 NMR OF 404121N/0741022W OR THE TEB219010.8 UP TO BUT
WITHIN A 30 NMR OF 405343N/0735807W OR THE TEB068005.1 UP TO BUT
EFFECTIVE 1010062100 UTC (1700 LOCAL 10/06/10) UNTIL 1010070015 UTC
(2015 LOCAL 10/06/10).
WITHIN A 10 NMR OF 405343N/0735807W OR THE TEB068005.1 UP TO BUT
EFFECTIVE 1010062330 UTC (1930 LOCAL 10/06/10) UNTIL 1010070030 UTC
(2030 LOCAL 10/06/10).
END PART 2 OF 5. WIE UNTIL UFN. CREATED: 04 OCT 15:55 2010
(Map it)
FDC 0/9203 - PART 3 OF 5 FLIGHT RESTRICTIONS CRESSKILL, NEW JERSEY
EXCEPT AS SPECIFIED BELOW AND/OR UNLESS AUTHORIZED
BY ATC IN CONSULTATION WITH THE AIR TRAFFIC
SECURITY COORDINATOR VIA THE DOMESTIC EVENTS
NETWORK (DEN):
A. ALL AIRCRAFT OPERATIONS WITHIN THE 10 NMR
AREA(S) LISTED ABOVE, KNOWN AS THE INNER CORE(S),
ARE PROHIBITED EXCEPT FOR: APPROVED LAW
ENFORCEMENT, MILITARY AIRCRAFT DIRECTLY SUPPORTING
THE UNITED STATES SECRET SERVICE (USSS) AND THE
OFFICE OF THE PRESIDENT OF THE UNITED STATES,
APPROVED AIR AMBULANCE FLIGHTS, AND REGULARLY
SCHEDULED COMMERCIAL PASSENGER AND ALL-CARGO
CARRIERS OPERATING UNDER ONE OF THE FOLLOWING
TSA-APPROVED STANDARD SECURITY
PROGRAMS/PROCEDURES: AIRCRAFT OPERATOR STANDARD
END PART 3 OF 5. WIE UNTIL UFN. CREATED: 04 OCT 15:55 2010
(Map it)
FDC 0/9203 - PART 4 OF 5 FLIGHT RESTRICTIONS CRESSKILL, NEW JERSEY
SECURITY PROGRAM (AOSSP), FULL ALL-CARGO AIRCRAFT
OPERATOR STANDARD SECURITY PROGRAM (FACAOSSP),
MODEL SECURITY PROGRAM (MSP), TWELVE FIVE STANDARD
SECURITY PROGRAM (TFSSP) ALL CARGO, OR ALL-CARGO
INTERNATIONAL SECURITY PROCEDURE (ACISP) AND ARE
ARRIVING INTO AND/OR DEPARTING FROM 14 CFR PART
139 AIRPORTS. ALL EMERGENCY/LIFE SAVING FLIGHT
(MEDICAL/LAW ENFORCEMENT/FIREFIGHTING) OPERATIONS
MUST COORDINATE WITH ATC PRIOR TO THEIR DEPARTURE
AT 516-683-2966 TO AVOID POTENTIAL DELAYS.
B. FOR OPERATIONS WITHIN THE AIRSPACE BETWEEN THE
10 NMR AND 30 NMR AREA(S) LISTED ABOVE, KNOWN AS
THE OUTER RING(S): ALL AIRCRAFT OPERATING WITHIN
THE OUTER RING(S) LISTED ABOVE ARE LIMITED TO
AIRCRAFT ARRIVING OR DEPARTING LOCAL AIRFIELDS,
AND WORKLOAD PERMITTING, ATC MAY AUTHORIZE TRANSIT
OPERATIONS. AIRCRAFT MAY NOT LOITER. ALL AIRCRAFT
MUST BE ON AN ACTIVE IFR OR VFR FLIGHT PLAN WITH A
DISCRETE CODE ASSIGNED BY AN AIR TRAFFIC CONTROL
(ATC) FACILITY. AIRCRAFT MUST BE SQUAWKING THE
END PART 4 OF 5. WIE UNTIL UFN. CREATED: 04 OCT 15:55 2010
(Map it)
FDC 0/9203 - PART 5 OF 5 FLIGHT RESTRICTIONS CRESSKILL, NEW JERSEY
DISCRETE CODE PRIOR TO DEPARTURE AND AT ALL TIMES
WHILE IN THE TFR AND MUST REMAIN IN TWO-WAY RADIO
COMMUNICATIONS WITH ATC.
C. THE FOLLOWING OPERATIONS ARE NOT AUTHORIZED
WITHIN THIS TFR: FLIGHT TRAINING, PRACTICE
INSTRUMENT APPROACHES, AEROBATIC FLIGHT, GLIDER
OPERATIONS, SEAPLANE OPERATIONS, PARACHUTE
OPERATIONS, ULTRALIGHT, HANG GLIDING, BALLOON
OPERATIONS, AGRICULTURE/CROP DUSTING, ANIMAL
POPULATION CONTROL FLIGHT OPERATIONS, BANNER
TOWING OPERATIONS, SIGHTSEEING OPERATIONS,
MAINTENANCE TEST FLIGHTS, MODEL AIRCRAFT
OPERATIONS, MODEL ROCKETRY, AND UNMANNED AIRCRAFT
SYSTEMS (UAS).
D. FAA RECOMMENDS THAT ALL AIRCRAFT OPERATORS
CHECK NOTAMS FREQUENTLY FOR POSSIBLE CHANGES TO
THIS TFR PRIOR TO OPERATIONS WITHIN THIS REGION.
END PART 5 OF 5. WIE UNTIL UFN. CREATED: 04 OCT 15:55 2010
(Map it)
